Help req'd RP2...
[Closed] Help req'd RP23 lockout problems
As above ,the lockout on the RP23 rear shock on my Ellsworth has stopped locking out,any home fixes or is it a trip to mr TF?Advice please
Posted : 30/06/2011 3:24 pm
 LoCo
Squelching? Leaking from adjusters? if so service time, it's not really a lockout but a low speed compression circuit that 'dials out' pedal bob when on.
Posted : 30/06/2011 3:41 pm
No squelching or leaks it just doesnt "lock out" in any of the three positions
Posted : 30/06/2011 3:46 pm
RP23 doesn't have a lockout does it?
Posted : 30/06/2011 3:52 pm
yes it does
Posted : 30/06/2011 4:26 pm
^The RP2323 does not have a lock out function, as Loco said, all it propedal lever does is increase low speed compression damping.
Posted : 30/06/2011 4:36 pm
Yes i know that but in position 1 or 3,i can't remember which,the bob is is reduced to almost zero effectivly "locked out"but whatever you call this function its not working so can i fix it or is it a shop job?
Posted : 30/06/2011 4:46 pm
 anjs
I had this with a RP2 where the pro pedal stoped working. Turned out I had a scored air can and a leaky main seal with nitrogen getting into the oil and cavitating.
Posted : 30/06/2011 5:29 pm
