Pretty sure I need a new part contained in the internals pack as the ball ended push rod doesn't click into place anymore.
Has anyone done this themselves? If so is it fairly straigh forward?
Posted : 18/09/2010 5:07 pm
Nothing too technical involved, loosen grub screw in lever and remove pivot pin, screw adjuster through barrel and remove lever, remove circlip and pull out adjuster and plastic clip that holds it(try not to let the piston behind come out or bleeding will be needed), re-assemble by reversing the above procedure.
Posted : 18/09/2010 5:20 pm
