help on nipple leng...
[Closed] help on nipple length
6 Users
about to build some wheels for the summer and was looking into different nipple lengths.
would longer nipples build a stiffer wheel?
cheers
Posted : 19/05/2010 9:33 pm
No
Posted : 19/05/2010 9:37 pm
cheers cynic-al =]
just assumed a longer niple would require a shorter spoke inturn building a slighly stiffer wheel
Posted : 19/05/2010 9:40 pm
I suppose you may be right but a few mm is not going to make any significant difference.
Posted : 20/05/2010 10:28 am
What you need are some Scania wheel nuts.
Posted : 20/05/2010 10:29 am
CRC seem to supply 14mm nipples with all their spokes but the DT swiss calculator defaults to 12mm.
Not sure other than a bit of extra weight what the relative advantages/disadvantages are though.
Posted : 20/05/2010 10:35 am
Longer nipples are for deep section rims, have poorer availability and greater weight.
Posted : 20/05/2010 10:36 am
just slightly longer than thumb and forefinger.....? 🙂
Posted : 20/05/2010 10:40 am
Yep 12mm is the 'standard' XM819s require 16mms, Sapim CX-Rays come with 14mm.
No real reason to use longer ones frankly.
Posted : 20/05/2010 10:44 am
