Help me! Genesis Co...
[Closed] Help me! Genesis Core 20 vs Boardman Comp vs ???
Looking for a 650b, ironically with a budget of £650.
This is mainly used for light trails over the south downs and through the forest. No downhill jumping hardcore stuff!
My initial search has bought up the Genesis Core 20 and the Boardman Comp form Halfords (which might me a worry!).
http://www.ukbikesdepot.com/m15b185s864p15207/GENESIS_Core_20_Mountain_Bike_2015/RS_GB/51602
http://www.halfords.com/cycling/bikes/mountain-bikes/boardman-mountain-bike-comp-ht-650b-2014
I know neither has a class leading fork, components etc but I am willing to upgrade parts as and when I need too.
So opinions on the above bikes would be great along with any other £650 opinions! Thanks in advance!
Posted : 29/03/2015 9:41 pm
I was looking at the Boardman in Halfords this afternoon, looked quite decent to me. Think the forks and gear-set is one stage better than the Genesis, albeit one is SRAM and the other Shimano.
There's the On-One Parkwood too, but its a touch over your budget.
edit - Sorry, the Parkwood is a 29er. As you were.
Posted : 29/03/2015 10:31 pm
If I was going for a fun bike then it would be the Parkwood despite being a 29er and £50 more.
Why 650b?
Posted : 29/03/2015 10:42 pm
Maybe I should sit on a 29er too. I just might be able to up the budget to £800 Max if I can sweet talk wifey!
Charge cooker 2 also comes in budget...
http://mobile.wheelies.co.uk/charge-cooker-2-2015-mountain-bike/p73965/?gclid=CO-Z9ODEzsQCFQEIwwodFWUArQ
Posted : 29/03/2015 10:45 pm
We're using Genesis Core 10s in the hire fleet this year and have been very impressed. Quality of finish is very high and they look/feel like a nicer bike than the price-tag suggests.
At this level any fork is going to be somewhat lacking, but it's an easy upgrade down the line.
If you can up the budget to £800 the Core 30 has a better fork and Deore 10-speed with clutch mech. Or have a look at the Saracen Mantra Trail for the same money.
Posted : 29/03/2015 11:08 pm
British cycling membership gets you 10% off in Halfords so if you go that way that'll help. I'd be stretching the budget and getting a Parkwood though. 😉
Posted : 29/03/2015 11:10 pm
Test ride.
Then decide.
Posted : 29/03/2015 11:11 pm
What bikes have you ridden and what did you not like or did like about them?
What size were they and how big are you.
Cube would be a good option good kit and lots of stockist so you could get a feel of what is good.
Posted : 29/03/2015 11:17 pm
Cube attention SL for £700 http://www.leisurelakesbikes.com/p/17523/cube-attention-sl-650b-hardtail-mountain-bike-2015
£50 more than the genesis but half a kilo lighter and better bits
Posted : 29/03/2015 11:19 pm
I have a Calibre Two Two, but its all a bit cramped and I bought in to it blind without trying it out. Not ridden for many years so this was my first mistake!
I'm looking for a fun bike that can be sourced and tried locally. The Boardman and genesis both can but so can the Mantra Trial that was mentioned earlier so might go have a look at that after work.
The other shop local to me does Cube so will pop in there too.
Thanks for the input.
Posted : 30/03/2015 6:45 am
Ok, so looking in some 29ers, the Diamondback Apex which can be had for £500 online:
http://www.bikes2udirect.com/B6107.html?mv_pc=gp1&gclid=CIK01u7lz8QCFUbKtAodWTQA7g
Seems pretty solid set up for the money and I have found a shop within a decent distance to go have a look at one.
Posted : 30/03/2015 10:51 am
Don't go and test one at an LBS then buy on-line. That's a low trick.
Posted : 30/03/2015 11:24 am
That diamondbacks well specced for the price, has a coil fork though. The boardman team 650b can be had for £560 at Halfords using B15BK08 for 10% off, another 10% for British cycling members and then pay in vouchers saving a further 10%. The voodoo bizango works out at £440 if you fancy a 29er
Posted : 30/03/2015 11:37 am
Ah cheers for that, very helpful. Will go look at the options over the weekend (but not test ride unless I intend to buy, if thats the case).
Posted : 30/03/2015 11:39 am
Ok if you want a fun bike then the Saracen Kili 29er or the Saracen Mantra 650b would be good options. The Genesis Core would be good a option as well you wont get as much spec as a cube but the frames will be better for what you want.
The 650b will be more chuckable the 29ers will maintain speed and lines better IMO.
I guess you are no where near Sheffield to go and try a Parkwood?
Posted : 30/03/2015 11:51 am
Bloody miles and miless away!!
I might go look at the Mantra after work as the guys who service my bike are Saracen dealer and think they have the pro in stock so can see what its like for size and get the Trail if its the right bike.
I like the look of the Kili, but the pro seems to have a worse fork than the Mantra.
Lastly, the Genesis, and although the spec is not great, I have been hearing good things about the frames.
Posted : 30/03/2015 11:57 am
If you're upping your budget to £800 I'd have this over the parkwood. Covers your criteria and then some.
http://www.planetx.co.uk/i/q/CBOO456CEVOX5/on-one-456-evo-carbon-sram-x5-mountain-bike
Posted : 30/03/2015 12:28 pm
I'm looking for a fun bike that can be [b]sourced and tried locally. [/b]
Posted : 30/03/2015 12:54 pm
Yeah really dont want to make that mistake again! Was looking at Giant (thre is a small giant store like 20 miles away), but seems only one really in my range is the 2015 Talon 2 27.5 but struggling to find any sort of reviews on it.
Posted : 30/03/2015 1:03 pm
The spec may not be the best with Saracen's or the Core but the frames will be more enjoyable.
Bother Saracen's seem to have same specs.
Posted : 30/03/2015 1:26 pm
spec wise the Cube Acid 27.5 is spot on and within budget. Also looks like you have a nearby dealer so can test ride.
I bought my son one at Christmas - Deore groupset and a decent air fork, quite light also.
Posted : 30/03/2015 1:31 pm
The thing I like about the Core is that it will leave me cash to spend on some extras (New shoes, clothes etc) and the frame is the same as the top spec model.
I think after reading through posts, reviews etc I will go check out the Mantra Pro (or the Trial - wife dependant lol) and the Core 20 with the view to upgrading the forks at some point.
As mentioned, it's not for anything super heavy right now so either should fit the bill.
Posted : 30/03/2015 1:32 pm
Voodoo is very tempting as a second bike at that price. What do you mean by discount for paying with vouchers?
Posted : 30/03/2015 2:11 pm
Just to throw a wilcard into the mix OP, if you're looking at 19" bikes we have a few of our 2014 ex-hire Mantra Pros left. We could supply and fit a new, higher-spec fork, and some of them have brand new wheelsets - and you'd still be within budget.
BBs, headsets, chains, cassettes etc all replaced as they wear so other than a bit of wear and tear to the frame (and there's not much) they're in good nick. Mail in profile if interested!
Posted : 30/03/2015 2:24 pm
What price you doing them for Drover?
Posted : 30/03/2015 2:38 pm
Details on vouchers here
http://www.hotukdeals.com/deals/22-off-any-purchase-halfords-1603626
Posted : 30/03/2015 2:57 pm
Cheers, long winded but good deals, surprised they've not closed the loophole. Probably too late to do this and get the current 10% off all bikes though as that closes tomorrow
Any idea if Halfords will apply these codes on bike to work purchases?
Posted : 30/03/2015 3:07 pm
It's possible, it'll depend on the staff. I asked at one store and guy said not possible. Ordered everything up at another store online using 10% code. Went to collect and used British cycling discount when I handed over my loc, no problem.
Posted : 30/03/2015 3:35 pm
So just popped in to my local shop on route home and they stock both Saracen and Genesis.
The Core 20 was ok but didn't really sell itself even when on board.
They had the standard Mantra in 17" and it felt really good. Was expecting it to feel small but the cockpit was rather roomy for a medium.
I think I'm going to go for the Trail but going to look at a cube first.
Posted : 30/03/2015 4:52 pm
I'm going to try the 19" in the Mantra too, just to make sure I'm getting the right size.
Posted : 30/03/2015 6:12 pm
£395 inc delivery, most of the remaining ones have a brand new set of wheels & tyres fitted too (from this year's fleet of Core 10s, funnily enough).
Could sort out a keen price on a fork upgrade too, if required.
Posted : 30/03/2015 7:45 pm
That's a pretty decent price! I think the 19" might be too big for me. Will try one out and see.
Posted : 30/03/2015 8:01 pm
I think I need to sit on the 19" as most size guides point in that direction for someone of my height (5ft 11, inside leg 32")
Posted : 31/03/2015 10:52 am
You probably need to try both for size probably the core looks like it has a decent reach and stack on them you are probably closer to the 19 than the 17.5. Though they come with quite a long stem 70mm if when you try it feels slightly stretched you could drop down to a 50mm or 40mm stem which would probably be better anyway short stem and wide bars are great for handling.
Posted : 31/03/2015 11:58 am
Yeah, will go try both. The Mantra has a longer top tube length, but cant find the stem length.
Posted : 31/03/2015 1:07 pm
jayx2a - Member
I wouldn't worry about top tube length, I firmly believe Reach and Stack are more important as they are the ones relevant to when you are standing on the pedals not seated.
17.5 inch core has a reach of 422
19 inch core has a reach of 447
17 inch mantra has a reach of 419
19 inch mantra has a reach of 442
Reach is calculated excluding stem length by the way,
Posted : 31/03/2015 1:46 pm
Ahh thanks. Not a huge deal in it bwtween the Core and Mantra, so will go try them all!
Posted : 31/03/2015 2:10 pm
I'm trying to find out the reach of my Calibre Two Two, but can't find the stats anywhere!
Posted : 31/03/2015 2:47 pm
The biggest difference between the Mantra and the Core Is the BB drop the Core Is 40mm compared to the Mantra 30mm. In my opinion that will make the Core a bit more planted and fun but you will have to consider rock strikes a bit more.
Posted : 31/03/2015 3:36 pm
Quick rides on Cube and Trek today have confirmed that the choice is either Core 30 or Mantra Trail.
Both very similar in spec bar the 2x10 vs 3x10 set up.
This is going to be a tough one! Going to give both a go again and make the decision.
Shop can order a new one in for me whatever I choose so crunch time. I know £800 is not the biggest amount of cash on a bike, but I need to get this right!
Posted : 31/03/2015 4:46 pm
Mantra has the better spec drivetrain 2x10 depression with clutch mech. Genesis has the 3x9 I would pick the one that feels the best though.
Posted : 31/03/2015 8:30 pm
Core 30 has the 2x10, the Mantra Trial is 3x10, both have clutch mech so guess it comes down to what feels right.
Will ride them both next week and make the decision!
Posted : 31/03/2015 8:58 pm
Now also looking at the Boardman Team. The thought of Halfords scares me, but the spec for the price is superb.
Posted : 03/04/2015 11:23 am
jayx2a - Member
Going to be honest I don't see what is very good about the Boardman Spec apart from the x7 rear mech the fork is probably worse than the Suntour. Definitely not worth the sacrifice in the frame.
Posted : 04/04/2015 11:29 pm
I like honest! It really helps me choose. If I'm being honest with myself I really should only spend £800.
The mantra trail was my first choice until reading about 2x10 and then doing google searches that mostly say 3x10 is pointless and 2x10 is better. Then reviews of the Mantra online say its such a fun ride, which I can't agree/disagree as rode one on tarmac only.
Then that sways me to the genesis core 30 with its 2x10 and very similar spec, but I'm not sure I like it as much as the Saracen. But the Genesis has the air version of the fork which I presume is better.
In other words... I'm a bloody nightmare!
Posted : 05/04/2015 9:54 am
You sure its a spring fork on the saracen? If it is it would tip me towards the Genesis. If it isn't I'd get the Saracen. Gears, shmears - remove some later if you don't need them.
Both look handy bikes. I got the Bizango as a 2nd bike - I've used little else since I bought it!
Posted : 05/04/2015 10:30 am
Spec or Saracen is here:
http://www.saracen.co.uk/bikes/trail/mantra-trail
And review
http://www.bikeradar.com/mtb/gear/category/bikes/mountain-bikes/hardtail/product/review-saracen-mantra-trail-14-48766/
No mention of it being air, but doesn't say anything bad about the fork.
Genesis has Suntour Raidon Air XC-LO-R-27.5, 120mm Travel
The Genesis sways me with fork and 2x10. Everything else says Mantra!
Posted : 05/04/2015 11:31 am
Look the same forks on both to me. I have the 15mm 29er version on the Bizango and they are more than decent, relatively light, adjustable for weight and the rebound adjustment does work. They are dead easy to service yourself too.
Sounds to me like you should go Mantra and then if you decide you can do without a chainring or two, just lose them later.
Posted : 05/04/2015 12:03 pm
Bizango was my 29er of choice, but prefer the 650b but having the 15mm is nice touch.
Think you sold me on the mantra!
Posted : 05/04/2015 12:54 pm
Do it now - your missing riding time!
Posted : 05/04/2015 1:59 pm
Yep, it's the same fork on both. Not a bad fork at this level at all.
You won't be disappointed in either of these bikes OP. If you can get a test ride on both then great, but there isn't masses in it. We have/had both Mantras and Cores in our hire fleet and they're a very good starting point - at the level you're looking (£200-£250 more than our hire fleet bikes) then they're very competent MTBs.
Posted : 05/04/2015 2:52 pm
Thank you @drovercycles they have both at my local shop so have been on both, but going to have one final look and ride after the bank holiday!
Posted : 05/04/2015 7:00 pm
I'm trying to decide if this colour looks nice, or horrible! I couldn't find anyone with a bike on show to have a look at:
http://www.saracen.co.uk/bikes/trail/mantra-elite
Posted : 06/04/2015 6:59 pm
Is your budget going that high?
Posted : 06/04/2015 7:13 pm
I'm considering a 1k budget... only because this will be it for a while and no upgrades for a bit so just thinking that little bit extra will make a big difference in the long run.
Was going to look at the Giant Talon 27.5 0 but not heard too many positives online about the Fox Fork
Posted : 06/04/2015 7:47 pm
Thing is with something like the Talon you are moving away from fun progressive geometry like the Mantra and Core and more towards traditional XC geo. At £1100 you might be able to pick up a Whyte 901...
Posted : 07/04/2015 5:15 pm
I looked at the 901 and sadly I can't find one for 1k and can't go any higher. There is another whyte 650b for 1k. Can't remember model but it was bright green!
The mantra elite may still be an option... The colour might be better in flesh!
If not I will fall back to the core 30 or trial.
Posted : 07/04/2015 5:58 pm
http://shop.birdmtb.com/zero/zero-7.html
Something to consider if you are near Swinley.
Posted : 07/04/2015 9:43 pm
