Help: MASSIVE negat...
Help: MASSIVE negative air pressure. Won't equalise - so can't service air spring.
 Oms
Hiya,
So I think I'm in a pickle. SID Ultimate (C1). Started feeling odd.
Trying to service the fork - when I let air out of the main chamber (no matter how slow), the air spring gets sucked all the way in.ย
There's a lot of negative air which won't equalise... which means removing the circlip will cause a kaboom, right?ย
My estimate is there's about 50 psi in there.ย
Personally, I'm not keen on being impaled by a Debon Air shaft.... or any shaft for that matter.
What items can I trouble shoot to get this thing off?ย
Posted : 08/06/2025 3:23 pm
This may be a transfer port issue.ย ย
I Google this: rock shox sid transfer port blocked
The AI summary looked mildly helpful but also.ย ย
https://singletrackworld.com/forum/bike-forum/pikes-sucking-down-transfer-port-clean/
ย
There was a suggestion in one of the other headline results that dropping the pressure 5 psi, pulling the fork up to fill extension and repeating until empty might work on another thread.ย ย
There were various YouTube videos too.ย ย
My suspicion is your underlying issue is the transfer port or damage to the air shaft.ย
ย
Posted : 08/06/2025 3:38 pm
Are the lowers off already?
Posted : 08/06/2025 3:42 pm
 Oms
Posted by: garage-dweller
ย
ย
Thanks - I re-fitted the lowers, re-inflated until the air spring stopped extending..... then I pulled/stretched the fork.
Upon pulling (or stretching) the fork, I could hear the hiss of it equalising. Dropped 10 psi at a time and repeated until it was sorted. 👌
Gave it a good clean - I was a bit more sparing with the SRAM butter on re-assembly.
Thanks again.ย
ย
Posted : 08/06/2025 4:34 pm
chakaping, nicko74 and anorak reacted
 DrP
Another way to overcome this is to just pump the positive chamber to 100+ PSI (i.e way more than you would ahve it set at) - this then overcomes the negative side, equalizes the chambers, and THEN you can let the air out again to your required pressure
DrP
Posted : 09/06/2025 9:55 am
Do the Debonair shafts still have the internal valve like the solo air did? if this happened with solo air, you could stick a long thing inside the shaft from the bottom of the fork (with the bolt out) and depressurise the neg side.
Posted : 09/06/2025 10:49 am
The only way I could solve this on my Revs was to sit on the front tyre and curl the bars up until it go past the clogged port with a massive pishhhhhhh. Working good as new now, which is still a bit crap. Moco damper is rubbish.
Posted : 09/06/2025 11:12 am
Posted by: DrP
Exact same issue as the OP happened to my SID Ultimate fork when I first got it three years ago and the above is what fixed it for me too. Once it had equalised I dropped the lowers and did a lower leg + air spring service with the correct amount of oil and grease and have never has issues since.
Posted : 09/06/2025 12:10 pm
 Oms
Posted by: devash
Posted by: DrP
Thanks both - a good one to have in the mental toolbox. 👌
Interestingly, there was air trapped in the stanchion too (upon first disassembly, I noticed the hiss). This is the third time I've done a lower leg refresh on these forks, but the first time I encountered both those quirks. 🤔
ย
Posted : 10/06/2025 7:56 am
