Help - fitting SRAM...
[Closed] Help - fitting SRAM Eagle crankset with threaded bottom bracket
I had assumed that the SRAM Eagle crankset would work with a Shimano MT800 Bottom Bracket. However there is play between the two. looking on the Internet it appears that I need a SRAM "flower shaped bearing shield" to go on the non-drive side between the bearing and the crank arm.
Should this be included with the crankset? There wasn't one in the box. Or is in included with a SRAM bottom bracket?
Posted : 19/01/2017 4:53 pm
You need a gxp specific bottom bracket
Posted : 19/01/2017 4:56 pm
Ours came with the SRAM gxp bottom bracket.
Posted : 19/01/2017 4:57 pm
You need a GXP bottom bracket, Shimano/Sram cranks aren't cross compatible.
Posted : 19/01/2017 5:04 pm
It's a bit more than the 'flower shaped bearing shield'.NDS bearing is actually a smaller ID than the DS one (see the step in the BB axle).
Posted : 19/01/2017 5:07 pm
Thanks folks. GXP bottom bracket ordered
Posted : 19/01/2017 5:15 pm
