Helmet - what to re...
Helmet - what to replace with, and when?
 Oms
Have a lovely Specialized S3 (about 10 years old)... managed to source the very last liner on earth to keep it going a bit longer. I love it because it's very light, tons of ventilation, and the visor actually does something in low sunshine. I used it for most riding until...
...over winter, I got myself a Tactic 4 for MTBing... feels a bit clunky to me, and the visor doesn't help me during late afternoon rides. It's OK.
Thinking I'll keep the Tactic for when it's muddy/minging, but looking for something to replace the S3 with. I like having a visor, and I want to use it for road/gravel/XC.
Any suggestions? Also, what's the advised life of these things (assuming you don't crash)?
Posted : 01/05/2025 8:35 am
About 5 years but it depends on how much it is exposed to sunlight so that obviously depends on how much you use it.
Posted : 01/05/2025 8:42 am
 Oms
Posted by: ernielynch
Ah - way overdue replacement then. It's done tens of thousands of miles.
Posted : 01/05/2025 8:44 am
nicko74 reacted
The ultraviolet light softens the polystyrene and makes the outer plastic shell more brittle. Obviously it will still give you some protection but I don't know how much it is likely to be reduced by - that's an interesting question
Posted : 01/05/2025 8:53 am
This is a good piece on the subject of helmet longevity from the NY Times:
When Was the Last Time You Replaced Your Bike Helmet? | Wirecutter
Dispels a couple of myths and basically says use common sense, I think.
Posted : 01/05/2025 8:59 am
My IXS Trail RS is 13 years old. I'm in NE Scotland though, so not the sunniest place on earth.
I was thinking about replacing it though, but only because I fancy something new.
Posted : 01/05/2025 9:34 am
The "Bicycle Helmet Safety Institute" says a 10 year old helmet is absolutely fine.
https://www.helmets.org/replace.htm
Posted : 01/05/2025 10:29 am
 a11y
Mine get replaced every couple of years - or sooner if I destroy it in a decent crash (as happened last summer - cracked in a head knock). Not through age, more just they pick up small knocks/bumps in general riding. Often due to me not ducking enough for low-hanging stuff being a lanky git. Probably nothing wrong with a few little bumps etc but when a decent helmet costs <£50 I don't mind the replacement cost to remove any dubiety.
Lazer helmets fit my particular head well, as did a Specialized Tactic (4?). Lazer Coyote (MIPS or KinetiCore), visor reasonably effective although mounts on the KinetiCore variant allows visor to move more easily than on the older MIPS variant - I assume intentional design to aid in a crash.
Posted : 01/05/2025 10:43 am
I'm looking forward to the 30th anniversary of my Met Parrebellum(?) in 2029 🎉.
Doesn't get loads of use as I typically ride without a helmet!
But it seems in pretty good nick. I wear a buff on my head with the helmet as the pads wore out around 15 years ago.
Posted : 01/05/2025 11:00 am
