Heatsinks - The fin...
[Closed] Heatsinks - The final piece to my light jigsaw
right so after the failure of my trailtech (rush) HID, i purchased the bits i needed for an LED conversion...
LEDs
Optic
Driver
New switch
So all that i am now missing is a heatsink. Bought some ally bar from ebay and was intending to get it turned down by a mate who has his own machine shop. However, he is just too busy with paying work to do it so need an alternative...
What can i use???
Posted : 21/10/2011 3:06 pm
[i]What can i use??? [/i]
coarse wet and dry and some elbow grease?
Posted : 21/10/2011 3:07 pm
needs to be metal. imo.
you might get away with a metal loaded epoxy/ ceramic type thing but you might be getting into v. specialist areas and they'll end up costing loads.
Posted : 21/10/2011 3:09 pm
believe me it had crossed my mind! but i need to take 12mm off, so i reckon it'd be after the clocks go forward by the time i'd finished..
Posted : 21/10/2011 3:11 pm
surely you can just by a slightly smaller diameter bit of ali?
Posted : 21/10/2011 3:12 pm
saw, then sand.
Posted : 21/10/2011 3:16 pm
hacksaw then use a Bastard File?
Posted : 21/10/2011 3:33 pm
Isn't the trailtech a plastic case? Fairly sure mine was.
I'd suggest a big one in that case ๐Ÿ™‚
Posted : 21/10/2011 3:57 pm
