headset questions
[Closed] headset questions
I've got a stanton slackline, currently fitted with 1 1/8 straight steerer forks with a nukeproof warhead headset. However I've just bought some tapered steerer forks, and wondered what I need to change on the headset to account for the wider taper. Cheers in advance
Posted : 14/06/2015 5:12 pm
I take it it's the 631 version with 44 head tube and not the 853 one?
also need to know headset make?
Posted : 14/06/2015 5:16 pm
631 yep. Nukeproof warhead 44IETS it says on the box
Posted : 14/06/2015 9:07 pm
Assuming it has the external bottom cup and a bearing with a 1.5" centre in the lower cup then all you will need is the correct crown race for the new forks.
The info on the headset I can find is a bit ambiguous unfortunately
Posted : 14/06/2015 9:22 pm
