Headset question. A...
[Closed] Headset question. A simple Yes or No... ๐Ÿ™‚
Is a Drop-in headset the same thing as an Integrated Headset?
Posted : 17/01/2018 11:39 am
maybe
Posted : 17/01/2018 11:40 am
It depends
Posted : 17/01/2018 11:42 am
Dammit.
Posted : 17/01/2018 11:44 am
Eranu.
Posted : 17/01/2018 11:49 am
This place used to be helpful. ๐Ÿ˜ฅ
Posted : 17/01/2018 11:51 am
What the bike, give us the info and we can google it for you ๐Ÿ˜‰
Posted : 17/01/2018 11:52 am
[i]This place used to be helpful.[/i]
Yes
Posted : 17/01/2018 11:54 am
Specialized?
My guess:
No
"Drop in" is only part of an headset? Can be integrated, can be not integrated...?
Guessing only.
Making noise
๐Ÿ˜ฏ
Posted : 17/01/2018 11:55 am
Well, I know which headset I need - this'un:
Now, a couple of brands that I've found (Ritchey, Syncros) call em drop-in and others call em integrated, so, as the Ritchey and Syncros ones are a bit cheaper and easier to get hold of.. well, y'knaa.. ^^ That question
Posted : 17/01/2018 11:57 am
That is a specific code if that is what you need then that is what you will get regardless of what it is called, it's a good bit of standardisation (or at least giving them all a name)
Posted : 17/01/2018 11:59 am
Yes. I think!
I think of them as "drop in" as you have noting to press into the frame like A Headset cups. You just drop em in and they mate to the angle in the head tube.
Was that helpful?
Posted : 17/01/2018 12:02 pm
answer will be printed on the crown race
... but you can only see that once it arrives ๐Ÿ˜€
Posted : 17/01/2018 12:03 pm
Not sure what you mean there Mike. See, the Ritchey, has that sizing, but doesn't use that exact code (or maybe it does and yet is called drop-in)
Here - http://www.chainreactioncycles.com/ritchey-wcs-headset-lowers-drop-in/rp-prod130225
Headset shopping experience is limited after having a Hope headset for 10 years not needing touching, then getting a frame with a tapered integrated Cane Creek and it going crap after a few months!
Sorry I thought you meant they both had that exact code, that is the bit that is the standard, all IS 42/28.6 top cups should fit the same.
Posted : 17/01/2018 12:06 pm
That's Cane Creek's headset finder result for my frame.
Posted : 17/01/2018 12:13 pm
Mu.
Posted : 17/01/2018 12:14 pm
integrated = the frame has a cup cut into the headtube.
semi-integrated = the headtube has a permanent cup fitted already that cannot be removed.
traditional press fit = you have to press in a cup.
work out which your bike has. But mike is correct, all headset labelled with that code will fit.
Posted : 17/01/2018 12:23 pm
It can depend on headset manufacturer but I found on Brand X tapered headsets the bottom bearings identical but the top bearing had an ever so slightly smaller outer diameter with the integrated set. The integrated coming with matching cups obvs.
Posted : 17/01/2018 12:26 pm
I know all those, ta. Question in first post still not really answered.
Posted : 17/01/2018 12:27 pm
Not the same thing but behave in a similar way, though the real answer is order one with that exact code on it.
Posted : 17/01/2018 12:28 pm
2nd post answers it perfectly ๐Ÿ˜†
Posted : 17/01/2018 12:35 pm
still - my guess:
Simple No
8)
Posted : 17/01/2018 12:39 pm
[i]2nd post answers it perfectly[/i]
Indeed. I'm glad it was simple ๐Ÿ˜€
Posted : 17/01/2018 12:43 pm
Yes, drop-in and integrated are [url= https://www.bike-discount.de/en/buy/ritchey-comp-headset-upper-part-1-1-8-is42-28.6-8.3mm-424730 ]used interchangeably[/url].
Assuming Cane Creek correctly identified the headset for your mistery frame, you should be able to use any IS42/28.6 IS52/40 pair. For the bottom part I'm pretty sure you could get away with the bearing and crown race from any tapered headset; as mentioned above, the top part may have a slightly differently sized bearing, so it would be preferrable to get the correct "IS" part.
That does make sense, however most of the time "semi-integrated" refers to zero stack (ZS) headsets, which are pressed in (integrated - IS, semi-integrated - ZS, external/traditional - EC).
Posted : 17/01/2018 1:13 pm
Ah yes!
Posted : 17/01/2018 1:19 pm
