Headset question
[Closed] Headset question
Just brought a frame with a tapered head tube and headset installed for tapered fork.
I want to fit a 11/8th straight steerer fork so assume i just need to replace the lower cup and bearing with a reducer cup and bearing.
What are the best options for this - finding online searches confusing.
What the simplest/cheapest option for this?
cheers
Posted : 22/06/2016 1:34 pm
simplest cheapest is a shim to increase the bottom diameter of your 1 1/8 fork to 1 1/4. the crown race will swap from tapered to shimmed straight, and the fork should fit as the old one did.
Posted : 22/06/2016 1:37 pm
Didn't know shims existed for use with steerers..but prompted by nedrapier i just found this...
http://www.workscomponents.co.uk/15x22-reducer-crown---for-fitment-of-1-18x22-forks-to-tapered-headset-245-p.asp
Would seem to be the cheapest, easiest solution - any reason not to?
Posted : 22/06/2016 1:54 pm
Actually there's loads of these available, but it's a case of getting the right one for the headset...or something that's going to fit right..no idea where to start on that one!
Posted : 22/06/2016 3:17 pm
The Hope one above, it fits on the fork and the original crown race fits on top of it..
Posted : 22/06/2016 5:14 pm
Cheers, that makes sense then, I was thinking it was a bottom cup.
Posted : 22/06/2016 6:47 pm
