headset Q - does th...
[Closed] headset Q - does this look right ?
[url= http://farm9.staticflickr.com/8167/7305493666_0d96904ff7.jp g" target="_blank">http://farm9.staticflickr.com/8167/7305493666_0d96904ff7.jp g"/> [/img][/url][url= http://www.flickr.com/photos/69346709@N08/7305493666/ ]Cycleofaddiction 1253[/url] by [url= http://www.flickr.com/people/69346709@N08/ ]cycleofaddiction71[/url], on Flickr i've been bugged that there's a seal missing on this especially since fitting a new fork a couple of months on from purchasing the bike from On One and finding no grease whatsoever in there
Posted : 31/05/2012 6:38 pm
Does look like a dust cover could be missing.
Posted : 31/05/2012 6:39 pm
Looks fine to me. There won't be any grease because it uses sealed bearings I'd guess.
Posted : 31/05/2012 6:43 pm
No its open cage bearing no seals anywhere i've seen a post recently about seals missing in headsets from On One
Posted : 31/05/2012 6:46 pm
Looks OK to me. Water rarely gets in the top race anyway.
Posted : 31/05/2012 7:06 pm
Thanks guys
Posted : 31/05/2012 7:11 pm
Looks wrong to me. The silver split compression washer visible should surely be under the top cap to centre the steerer/bearing race. Too many spacers also ๐Ÿ™‚
Posted : 31/05/2012 7:16 pm
Coleman - Member
Depends how its meant to be assembled - all mine are like that
Posted : 31/05/2012 8:02 pm
At the expense of possibly sounding thick - what's actually applying any preload to the bearings if the nearest clamped item is 8 - 10mm away?
Posted : 31/05/2012 8:10 pm
I have 2 FSA headsets and the split compression washer is under the top bearing cover on both.
Doesnt look right to me.
Are you not able to get a exploded diagram off FSA to see how it should be built up?
Posted : 31/05/2012 9:04 pm
chives - the spacers transmit the compression.
Posted : 31/05/2012 9:06 pm
Not if theres a brake cable hanger clamped onto the steerer between two spacers they dont. (Thats what it looks like anyway!)
Posted : 31/05/2012 9:29 pm
Has he not just moved it up to take the photo!?
Posted : 31/05/2012 9:36 pm
there is a spacer betwixt* headset and brake hanger.... i'd guess he tightens the top cap bolt, and then the brake hanger.
*brilliant word ๐Ÿ™‚
Posted : 31/05/2012 9:40 pm
As coleman says, youve put the silver bit with a cut out in upside down.
Posted : 31/05/2012 9:42 pm
