Head set
[Closed] Head set
Hi all
Striped out my FSA 1/18th headset to give it a service. found it hasn't got sealed bearings. gave it all a clean, greased it up and put all back together.
Defo need to replace the bearings. they are well worn. Will a set of sealed cartridge bearings drop straight in to save buying a new headset.
Seen some on CR but not sure if they will drop straight in
Its only 15 months old
Thanks
Posted : 09/07/2014 7:57 pm
Do they run in a separate races or on the headset cups and crown race?
Posted : 09/07/2014 8:02 pm
They sit straight in the cup top and bottom. Once they are in there is a split metal seal that drops inside and then a flat seal that that sits in top and is held in place by the cup
A final split seal then drops in on the top only
Thanks
Posted : 09/07/2014 8:47 pm
Ditch the whole lot then.
Nothing wrong with loose bearings but you need to look after them to preserve the bearing surfaces. I am guessing the cups are steel too? Probably quite a heavy headset.
Posted : 10/07/2014 1:25 pm
