Never removed these before and i'm really making a meal of it.....
I have the removal tool but cant work it out, can anyone give me step by step idiots instructions or post a link please?
Thanks in advance
1. Screw in the removal tool (reverse thread IIRC)
2. undo the crank bolt and the removal tool plus the bolt will act as a self extractor.
Oh, you need to remove the plastic thread protector with teh removal tool before screwing the removal tool in!
[url= http://www.parktool.com/blog/calvins-corner/2007-shimano-xtr-components#crankset ]http://www.parktool.com/blog/calvins-corner/2007-shimano-xtr-components#crankset[/url]
Does this help ?
you do need the tool though!
http://www.cyclistno1.co.uk/features/maintenance/servicing-xtr-cranks.htm
foxyrider - you don't put the plastic ring back in the crank arm in your 'how to'?
Thanks guys, worked it out!
Problem was apart from me being a moron was i removed the bolt.....doh!
WW - I did:
Use the reverse side of the Mounting Tool to re-install the crank arm cap – this should hand tight only.
But I have just put an image in to make the point?
LOL
