That wazoo above. Does adding electric really cost £1000?
My brother and his wife recently rented e fats in the Alps and loved them.
Could they buy a wazoo each and convert them themselves? He is a sparks so that should help.
Many people may have been persuaded they need one when it was inappropriate, but that's what happens if you depend on sales staff, magazines and social media for your decisions.
Strange, when most MTB media is overwhelmingly negative towards fatbikes, writing them off as slow, heavy and a 'fun' addition to a fleet but not a 'real' MTB.
It's almost as if some are actually selling on merit, rather than marketing....
"but it makes a lot of sense if you plan to hammer one as an AM bike, and correctly chosen and specified, they can be excellent for such use."
if you want any decent kind of battery - yes. - if not more. A bafang bbshd 1000w and a battery will be an easy 1500 quid.
a bbs02 can be done for around a grand
fitting one of the cheap hubs makes the bike handle like a pig and depending on the hub - draggy as hell.
I have a Felt Lebowske e fat bike.
Makes a lot of sense.
Agree about the fork options.
Bike came with a Bluto, rode it a few times, but didn't think much of it on a 20kg bike. It's a rehashed Reba in essence, might be ok on a normal fat bike though.
Also go a Lauf Carbonara, which I like, but it is not a charging around regardless fork, great for cross country riding at a more relaxed pace though.
There is another option.
The Wren fork. A proper fat bike fork available in different length configurations, user serviceable, not as refined as the current state of the art fork manufacturers though.
Takes some time to bed in and understand how to set it up.
A very good option on a e fat bike, it has 36mm stanchions, upside down, dual air chamber.
The best option at the moment.
Personally I think fat bikes are too fat - In so much as - why do you need a fat wheel on the back?
For UK riding anyhow. If you are riding on Sand or Snow then fair enough. But if you just want to tear about through the winter slop then a Fat front wheel is enough.
The float given by the massive front tyre means you can do away with the delicate front forks....which is a benefit for a low maintenance winter bike..and at the same time the loss of mass from the suspension forks offsets the weight of the fat front wheel.
But in terms of float there is no benefit to a fat wheel on the back, all you add is extra drag...if you are going over bumpy ground even with the big front tyre your speed will be limited by the punishment your arms can take - your back wheel will follow along just fine since your knees are excellent shock absorbers. Same principal as a hardtail.
In terms of grip on those fast off camber loamy downhills we all love - where do you need it most - on the front.
In terms of peddling traction - I find I get more from a narrower tyre on the back to cut through the worst of the slop while the big front wheel glides over the top. In really marshy ground I put all my weight over the back wheel and spin away in an easy gear - and we chug along like a paddle steamer.
It honestly is the most versatile setup Iv ever had...its my most used bike. It might look weird but who cares
That's an interesting idea. Are you saying I should chuck a rigid fat fork and wheel on the front of my normal bike and have a play? No frame or drivetrain changes need. Might look fugly, but I'm tempted.
Similar to the Jones Spaceframe really.
I had a Jones, but couldn't get on with the totally rigid fork.
More to do with me than the Jones in truth.
Really good bike, I wanted to like it, but simply couldn't gel with it.
Fat front end and 29er rear wheel.
Aagh! This is bad practice, it cuts up a very fragile surface and just leads to it becoming a quagmire.
Tons of grip without the drag
If you can provide the legs it despatches technical climbs. roots rubble steps no skills required just ride up
The grip works with braking as well. No need to drag just short stabby braking that would overwhelm thin tyres esp in loose conditions
that's exactly what I did to my Inbred - cost hardly anything with second hand on-one parts. its amazing. Some people use 29er frames to match the wheel sizes up but mine is a 26er. I like the small wheel on the back - makes it slacker and more hooligan for me 🙂
I also run an Alfine hub gear for extra winter-proof-ness.
I'd be lying if I said/wrote that the random thought of seeing if anyone wanted to buy my default Wazoo fork and front wheel had not crossed my mind, once I have the Carbon fatty Fork installed.
Presumably you would would need a 29er frame as the recipient, with something like a 29x2.35" tyre installed on the rear.
I took my "proper" mountain bike out for a spin the other night to reflect on some of the comments made in this thread. This bike, which has all the bells and whistles of a modern mountain bike (full-suspension, lots of pivots, long, low, slack, big wheels, short stem, wide bars, Pike etc) has been sadly neglected since getting the fatbike. So, why would I choose to ride a heavy steel, rigid bike with 5" tyres over a modern trailbike?
Honeymoon period? Could be. New bikes are always fun, but as I approach 50 hours in the saddle that seems less plausible.
Attention seeking? Unlikely. I rarely meet another soul on most of my rides and that's the way I like it. In fact I actively seek routes where I'm unlikely to meet anybody and the attention is probably the thing I like least about a fatbike and what puts me off riding it on more popular routes.
Capability? That's definitely a factor. Big tyres coupled with a slack head angle and a geometry that doesn't change when you hit a bump does allow me to ride up and down stuff that I either can't or won't tackle on a regular bike. Plus you've got those places that you can't really ride a normal bike like, sand, snow and bogs.
Comfort? Yes, I was surprised by how uncomfortable my full-suss felt after the fatbike. Yes; it copes with bigger bumps much better, but regular trail chatter gets through much more.
Simplicity? Maybe; there is something satisfying about the lack of complex suspension. But I quite like tinkering in the shed, so that's not a big factor.
Efficiency? Yes, my Smuggler is reckoned to be a pretty efficient climber, but after riding a rigid bike for a while it was amazing how much I felt the suspension (even with pro-pedal on). It was probably just psychological, but it did feel a bit like riding through treacle as the suspension seemed to soak up some effort.
In the end through, I decided that I couldn't really put my finger on it. I just kind of enjoy the big heavy lump 🙂
That's a lot of words, so have some pictures to go with them.
I'd disagree and say the opposite would be a far better bet. 60-70% of your weight is on the back wheel, that's where you need the float in winter.
@ RP - I also took out my 'regular' MTB (29er HT) yesterday to celebrate 30 years of my MTBing this month.
However, as good as it was, I found myself planning to do the same ride on my heavy old school fatbike ASAP!
Once again, your post will look like it's me under a different username if I showed my family 😆
Depends on where you ride. I turn right out of my house, have a mile of cart track and on to a moor. The track over the moor is a line on a map, so it's grass, bracken and rushes. You can't ride a skinny bike on it in the winter (I can't anyway).
Then it's onto a fast flowing trail centre where I'm just as fast (or slow) on the fat bike.
I won't be buying a skinny bike again.
And... road bike vs fat bike on my local mountain road loop the fat bike is only 10% slower...
Ah yes, the mystery of speed. I must admit, I've given up trying to make sense of this. My fatbike weighs 34lb and has 5" tyres. So, we can all agree that it's slow. I mean it has to be right? The fact that the Strava data contradicts this is obviously irrelevant 🙂
I ride the same stuff on both my bikes and tbh there's little that the fatbike's faster for, and lots of stuff it's miles slower. But that doesn't change the fact that it's just as fun- and different fun, not better or worse fun.
What Northwind said.
I ride my Fat Bike because it's different and I enjoy riding it, the rate of sales my have slowed but that doesn't mean there was a bubble.
Just to clarify, there are certainly segments where my fatbike is much slower. In particular, those long fast rocky descents, where I can just lay off the brakes on the Smuggler and let the suspension soak up the bumps. On the (rigid) fatbike I get tired and either back right off or just stop and admire the view for a bit. No less fun, but slower.
In fact, if you only care about downhill sections I'd agree with Northwind. There aren't many sections were the fatbike is faster (although plenty where it is pretty much the same) and some where it is a lot slower.
What shocked me though was the climbing ability. Despite the weight, the combination of grip, efficiency and tyres that roll over stuff just seems to translate into much faster climbing that I expected. I've even set PRs on smooth fireroad climbs. But then, I'm one of those weirdos who enjoys climbs every bit as much as descents.
I've not found that. It's all very close and 50/50 which is faster. I'm pretty sure I'm less fit than when I set my skinny times too.
Other than local terrain, which for me I think suits a fat bike, I think fat bikes work better at slow speeds, so a faster rider would find a fatbike a handicap and a slower one wouldn't.
@roverpig - yet to get and ride the fat bike but I've got B+ wheels for the 29er and even that small increase in volume and tyreprint makes a difference despite the wheel/tyre combination being 1.5Kg heavier. If it's a loose or rocky surface then I'm about 10% faster on the plus tyres when climbing, it's the amount of extra grip/traction plus you don't get deflected from your intended line as much.
The undamped suspension effect can be, err, interesting. 😳
Logically, fat bikes make next to no sense for normal trail riding. And intuition tells us they'll be slow and draggy. Fortunately, there's more to MTBing than logic and intuition. 😀
Fortunately we have Strava!
There seem to be at least two schools of thought often put forward by fans of fatbikes. On the one hand you've got those who argue that it's stupidly inappropriate and that's the appeal Northwind makes this case very eloquently, for example. On the other hand you've got a minority (see, for example, [url= http://singletrackworld.com/wp-content/uploads/2016/03/ten-reasons-why-a-fat-bike-should-be-your-only-bike/ ]Sanny's article[/url]) who argue that a fatbike is actually a perfectly viable option. I started in the first camp but am tending to drift to the second.
I think it depends very much on how and why you ride. For "proper" mountain bikers a "proper" mountain bike is the best tool. Anything else is sub-optimal. Maybe in a fun way, but sub-optimal all the same. But, for riders looking for something other than the adrenaline-fuelled gnar-fest that seems to be sold as the only true form of mountain biking, they can make a lot of sense.
Still, who wants sense 🙂
Totally unscientific, but by and large most people I know who have a history going back to childhood with the outdoors tend to be less inclined to try to paint fatbikes as a fad whose time is over.
I call non story, tbh. There are obvious fashions in the MTB industry. Not being on trend only makes you irrelevant to the easily led. At the end of the day, they're simply bikes that look different.
I'm with Roverpig - i prefer riding my fat bike to my other bikes. Why? So many different reasons!
I have a well sorted 160mm trail bike - and this is clearly better for big days out with big rocky descents. Maybe 6 times a year
I also have a Solaris - nice build. It should be the best tool for my local riding in Berkshire, Surrey & Hampshire
But i still choose the fatbike for 90% of my riding because its such a complete bike. I have to work harder to make it travel at the same speed as my pals - so great training
Its an absolute hoot on any downhill sections - imagine the nostalgia of riding something from the early 90s, but with proper brakes. I always end up grinning like a fool
Importantly though, i'm just as fast on local singletrack on the fat bike as on my 160mm bike (and certainly quicker than the Solaris)
The rigid bike rule - you have to work on your lines!
The fatty is brilliant for bikepacking and can climb anything - i really think i could climb a tree on it
Maintenance costs are tiny. One new drive train a year. My front tyre, a Nate, has over 4,000 miles on it. I've just replaced the rear Mammoth which had about 3,700 miles on it
Fork choice - tried Blutos - didn't like them and thought they ruined the concept of fat biking, so sticking to rigid
Downsides - its a pig on tarmac. However, i always avoid the road at all costs
I've got both an On-One Fatty and a Singular Puffin - the On-One really is a good bike - which is annoying considering the money i spend building the Puffin
Conclusion: I ride for fun, fat bikes are fun so its a perfect combination 🙂
As I posted (ages ago), who is the comment aimed at? It's not the sort of thing that is a typical press release to the bike media, sounds more like a warning to investors that things are going to get tough [b]for them[/b].
Away from the more specialised retailers like Charlie the Bikemonger fat bikes are definitely "niche". The bike shop just up the road from me now is one of the largest around and while a couple of years ago it had a handful of fat bikes in store now it has none. In their place are a handful of "plus" bikes. No doubt in a year or two these too will be gone to be replaced by the "new thing". (The shop probably has over a hundred mountain bikes on display to give some perspective) As far as I can remember they've never had tyres for fat or plus bikes in stock - "we can get them for you sir", well, yes, I can go on the web as well, that's not the point.
Like a lot of things there'll be aficionados who only ever ride fat bikes, those who've a fat bike in their collection and use it fairly regularly, those who've a fat bike and rarely if ever ride it and those who wonder what the fuss is/was about.
Like all bikes they are a compromise, if those compromises work for you then great otherwise it's "nothing to see here". In either case carry on riding your bike(s) and enjoying yourself.
Nail on head, whitestone.
The only thing that keeps me from fatbikes is the larger Q-factor, causing pain in the knees.
This makes me look at bikes like the Orbea Loki B+
A pity, as the Canyon Dude rigid fatty is a fantastic fatbike imho...
The Dude is glorious tbh, it feels like the initial design was done by a 5 year old,it's a proper caricature of a bike.
Have you tried the wider Q factor? My ICT is about as wide as they come and I was concerned that it might be a problem. Fifty hours in and all seems fine on that front though. In fact I did get some knee pain for the first time in ages after riding my normal bike again the other night. Could just be coincidence though and I do walk like a duck, which might be a factor 🙂
Boltonjons post sums it up for me
trout - Member
Yep, I can echo that too.
Cheers boys - glad we're on the same page 🙂
+1 for boltonjons post...
Ive ridden fat bikes for about 6-7 years now, back when you had to buy a frame and build one, and had 1 choice of tyre (endomorph)
I love them, they are not always to best , but are fun, I don't care about being quick, but for me they are the real All Terrain bike
bridleways about 6" deep in sand, no probs, snow - Im out riding in it, marshland, that too, heather, broken, stubble fields, beach cobbles, rocks, all fine my me
I've had
surly pugsley, 9zero7, carver Ti, surly moonlander, cannonade caad fat 1, single speed pugsley, hai bike fat six
At the moment, this hai bike (e bike) is my go to bike, its just amazing, just had new wheel set built onto orange hope hubs, camo hydro dipped rims, brake upgrade etc etc
I couldn't care if anyone elses bubble has burst, mine hasn't
[URL= http://i46.photobucket.com/albums/f144/kingcozmo/IMG_3360_zpsav10aux1.jp g" target="_blank">
http://i46.photobucket.com/albums/f144/kingcozmo/IMG_3360_zpsav10aux1.jp g"/> [/IMG][/URL]
[URL= http://i46.photobucket.com/albums/f144/kingcozmo/IMG_3403_zpsvczcduai.jp g" target="_blank">
http://i46.photobucket.com/albums/f144/kingcozmo/IMG_3403_zpsvczcduai.jp g"/> [/IMG][/URL]
wow Cozz that's some peace of kit
That carbon frame and rigid carbon forked Canyon Dude looks lovely to my strange tastes, but I could not justify (or afford tbh) to spend ~4x what I spent on the Wazoo.
If someone's bubble has burst and they want to swap their fat bike for my Giant TCX SLR2 I'll help them deflate 😆
After my brief relapse back into normal mountain bikes, it was fun to take the fatty back out again this weekend and I had something of an epiphany. I said that the only area where I feel the fatbike doesn't work (for me) is fast rocky descents. It's not just slower here, it's much much slower. However, it's not so much that I can't ride it fast over this terrain it's that it takes much more energy to do so. Mental and physical; picking lines and moving the bike around. Since I enjoy a good climb, I'm often knackered before I start the descent. So, after a few minutes on the fatbike I'm having to throttle right back just to get a rest.
I also realized that it's not just a case of the fatbike being slower on these rough descents than my full-suss. It's also much slower than my old (Solaris) hardtail, which is making me wonder about a Bluto.
While I contemplate the enormity of that decision, here is a picture from the weekend.
I don't think so. Several of my mates ride fatties around the Surrey Hills. These are not weekend warriors, they ride hard and often and they love them. They ride everything. Might get one myself.
Holly thread resurrection !
I notice there are three high end fatbikes on the first page of the classified section today (none in my size fortunately). That's at the height of what might traditionally have been thought of as fatbike season.
There have also been comments from the Singletrack crew about the lack of fatbikes at shows (particularly compared with the last few years) and we're still waiting for anything to rival the Bluto (from a cost/performance perspective).
Obviously fatbikes aren't going to die, but those of us who like them probably aren't going to have too many new options (bikes or components) to drool over. Might be some bargains to pick up though 🙂
Maybe a better way of looking at it is that the "ooh! a new type of bike, I'll get one and see what it can do" effect has worn off and the early adopters have all got one or sold theirs on. People generally know now what a fat bike is good at and whether it fits in with their scope of riding.
roverpig - MemberObviously fatbikes aren't going to die, but those of us who like them probably aren't going to have too many new options
Sure, but that's inevitable- just the transition from a growing market to a fairly full one. Possibly a little overfull, up til now it's been rapid expansion but sooner or later it'll turn fully into market share scuffling.
I don't think most nouveau fat riders think there's a "season" tbh, not one revolving around UK snow anyway... Probably for beach riding summer is better, for trail riding which is what gave the niche its growth, probably they're worst in winter after all. So except for a real snow bike I wouldn't read much into that.
If the fatbike bubble has burst I'll take a nice carbon bluto'd up one off your hands, I won't even charge.
It's a good point about the "season" in the UK. I did use our Scottish winters as an excuse (to myself) for getting the fatbike. But, in practice, I do very little "traditional" fatbiking as that isn't really the riding I enjoy. The fact that I can ride on snow, for example, is impressive. It can sometimes make the difference between getting a ride in and not and if I find a bit of snow on a regular ride I'll have a play in it. But in all honesty, given a choice, I usually pick the route with the least snow as mostly it's just a slog. The same with sand. A bit of beach in the middle of a ride is a laugh, but I wouldn't ride sand all day as it's mostly either a slog or a bit flat for my tastes.
Agree.
Snow, sand and comedy frame bags are very nearly every thing I hate about fatbiking. The first two are entertaining once in a while but can seriously up your maintenance costs.
My fatty is a simple trail HT, just with added traction - if it has a season it's the same one as every other MTB, one that depends on the rider.
Any bubble bursting has been the slowing of the curious I think. Possibly most people that wanted one have one, possibly On One just sold so many bikes that are now with second and third owners... There's a large Fat presence out there that isn't going away.
As indicated in the lightweight fat bike thread, Doverbike and myself were out in Finland for the Rovaniemi races. Generally the terrain isn't challenging in the sense that you aren't doing trail centre type trails (and going "off-piste" by even a metre is interesting! 😳 ), it's very much traditional style XC riding where fitness is important at least as much as being able to get air.
If your main interest is riding trail centres then a fat bike is really just an amusing sideline. You'll have fun but a far, far, better bike is the modern full suss: trail centre and FS development have gone pretty much hand in hand - riders get a better bike so trails become "boring", trails get toughened so they are interesting to those with the latest bikes, riders get a better bike, etc.
There'll be some model rationalisation as Northwind has said but the UK, as ever, is really just a small market in the general scheme of things, there's a big fat biking scene in the US but they've the terrain and weather to suit. Look at the number of endurance/ITT type races in the States vs Europe, roughly 20 to 1.
Edit: understand the comment about riding in sand increasing maintenance but riding in snow doesn't - proper snow that is when it's genuinely cold - the bike gets back from a ride in exactly the same state you set off.
Not for me at least 🙂
Converted my full suss trail bike to fat front, got fatty single speed/geared fully rigid bike, bought another frame to make it more trail oriented...
Life's good at the mo 🙂
Cheers!
I.
Search for Gartner Hype Cycle. I've linked to it previously. It refers to IT developments but applies to many other things, including consumer goods.
I don't own a fat bike, though I would if I could!
What I don't get is why quite a few people are willing, really willing the fat bike to die a death.
Why is that?
Poopscoop - Member
I don't own a fat bike, though I would if I could!What I don't get is why quite a few people are willing, really willing the fat bike to die a death.
Why is that?
(a) It challenges too many preconceptions and prejudices. For years we've been chasing lighter, longer travel. Lots of that stems from the input of those that race, as if that had anything to do with the vast majority of riders. Fatbikes are mainly about fun, lots of folk don't get that.
(b) Too many fatbike messiahs proclaiming they are the best bike for every trail.
One of the original attractions of fatbikes was that they were somewhat isolated from the constant development cycles of other MTBs (being somewhat simpler). I know quite a few of us who bought in early are still running older bikes. You can also buy a decent fatbike for not much money. I therefore think that "high-end" fatbikes will struggle to attract any meaningful resale value.
Some kind of bubble has burst; I only remember seeing 1 fat bike at the London show, last year there were loads
I'd been after one for some time and finally got one this December past. I absolutely love it. Yes it has a comedy element but it's also very capable. It's undoubtedly the best climbing bike I've ridden (better than my Anthem)
Perfectly happy for fashion to move on elsewhere. I'm happy to be the only fatster on the trail
MTB manufacturers probably hate them as it's against their business model of deliberate obsolescence - they'd rather sell 10mm of more suspension or an e-bike. It was 29+ and fatbikes that have got me interested in riding MTBs again - simple, low maintenance and capable of riding almost any terrain. If I want to ride fast offroad, I have 2x CX bikes.
+1 to that Colin. My Puffin is either a prototype or one of the early production models, don't know what Ian ended up with before he sold it on to me. I've no desire to fit a Bluto fork to turn it into a trail centre oriented bike, it runs fine as it is.
Fat bikes will be:
a) ideal in some situations
b) OK in quite a lot of situations
c) crap in the remainder
A bit like most other bikes really. Depending on where you live and what trails/bridleways/terrain you ride a fat bike will be suitable some or none of the time. Unfortunately that isn't black and white enough for some people and they have difficulty in understanding that there are shades of grey.
Hopefully not burst, may treat myself to a cheap one next winter as I have a beach right on my doorstep.
I love my Fatty a Trail. Just not as much as my Fatty. So I'm taking off the 120mm Bluto and Reverb, changing tyres and I know I'll be having fun again. I ride too much on road and canal path for it to be my only bike but I really would miss it.
Well I rode my Pugsley from Sand Bay to Burnham last week, along the beach, forest single track, cycle path and road. V pleasant. If the bubble has burst I'll be happy to pick up nice fat bits going for bobbins like the amazing 26er stuff I've got recently for peanuts......
Hope it has burst. Cheaper bits - especially tyres.
Maybe, but with on-one leaving the market that means no more floaters which were the only 'good value' option, anything else is two to six times the price, and anything the same price is a bit crap.
Mount Fernie, rob?
Yep, Ned. Just on the banks of the Elk river where we go to drink a cold Kokanee and watch the ghostrider appear in the summer sunset on Hosmer. Home is in the Annex.
Still love my fatty 🙂
I now ride fat bikes more than any other type of bike. My current long termer is a Cannondale with a lefty fork. It is great! Much more testing to be done. My last one was an ICT which I bought. I'm hoping my next test bike is a Salsa Bucksaw as full sus appeals!
Sanny
I'm not really concerned about whether fatbikes are good or not, I'm a fully paid up member of that club, but I'm still concerned about the bubble bursting, for two reasons:
First, I don't think we've got them right yet. The ICT is a far better fatbike for the type of trail riding that I enjoy than the early snow-focussed bikes, but I'd like to see what a few more years of innovation could do. It stands to reason that sticking honking great wheels on a bike will change optimum trail geometry, but I'm not sure we know what that is. We need a sustained high demand to make it worth manufacturer's time to test new designs.
Second, the whole attention grabbing thing is my least favourite aspect of fatbikes. I just want to ride my bike in peace, so it would make my life easier if they weren't quite so unusual.
(Second, the whole attention grabbing thing is my least favourite aspect of fatbikes. I just want to ride my bike in peace, so it would make my life easier if they weren't quite so unusual.). Exactly this.. although I don't get many comments as I'm either out and about too early or off the beaten track
Buy a set of Pogies. When folk see them, they magically miss the wheel size.
TBH I get a lot fewer comments these days. Maybe because they're quite common in this neck of the woods and if I'm further afield it tends to be well off the beaten track.
In my LBS the staff there are almost all on fat bikes, they have a fat bike ride once a week and keep trying to convince me to join them. Not my cup of tea but they obviously find some long-lasting appeal to them out of all the bikes they stock.
roverpig - Member
Hey RP, hope all is well with you and yours.
I can't help feeling that this is the double edged sword that bursts the bubble, or at the very least let some air out! High demand got the big manufacturers attention and they jumped on the bandwagon. Leading to the market getting somewhat flooded. This squashes the development being done by the more fatbike orientated manufacturers who just can't keep up/compete with the big boys in terms of buying power (then spec) and marketing budgets.
All just IMHO of course.
And a fine opinion it is too 🙂
Actually, it is a very good point. The big guys jumped into the market to cash in on the bubble, but (as far as I can tell) didn't offer any innovation; just flooded the market with similar bikes to what were already out there, taking away the incentive for the smaller players to innovate. Maybe that wouldn't matter if demand stayed high as the bigger players would then have to innovate to compete with each other. But as it stands, it looks as though they've just killed off the smaller players then run away.
But then it's doubtful if we'd have seen Rockshox launch the Bluto while fatbikes remained more niche.
Ah yes, that does kind of shoot my argument down in flames. Where is the crash and burn emoticon 🙂
Incase it hasn't been said already, fatbikes seem to make a lot of sense as e-bikes.
Saw a YouTube vid of surly e-bike conversions in NYC. Looked like fun.
Kind of like when mountain bikes started to gain popularity in 1989...
Maybe a simplified version to entice the commuters?
While I appreciate the fatbike's forte is off-road, I'm saddened at the lack of fat tarmac-specific tyres out there. And the only one out there of note, the Vee Apache Fatty Slick, seems to be taking an age to reach the UK shores (and I still dread how much it will be listed for, given the eye-watering $120 price at https://www.veetireco.com/listings/fat-tire-apache-fatty-slick/ ! 😯 😯 😯 ).
Hindsight is a wonderful thing, but part of me wishes I had dived in head first into fatbiking with something like the rigid forked, carbon framed Canyon Dude. Now I'm putting regular 50+ miles on the road weekly, I'm starting to get a little frustrated by the Wazoo's weight, especially in the default wheels (~3700g?). But even with the FatNotFat wheels, it's still a portly ~12Kg bike, before I get round to having the carbon fork installed (which will save another ~900g).
But with the post-referendum pound weakening and consequent price hikes, a Dude is realistically a non-starter for me now. Consequently, I'm loosely toying with the idea of a hydraulic adventure bike like the Arkose X, which then makes me wonder if it's worth keeping the Wazoo should I buy an Arkose.
I guess I'm questioning my purchase more now because so much has changed in a year, I'm ~14Kg lighter; considerably fitter; my old lower back injury is giving me far less grief; despite my front end spill two week ago I'm now feeling the need for speed (something I very much lost after my freak RTA).
Not to mention, I handed over ~£400 after discounts and vouchers to buy the Wazoo last year and excluding consumables (tyres; chains; cassettes etc.), I've spent at least that on component purchases, way more than I've spent on all my other bikes over the last 30 years combined... It's starting to feel like an absolute money pit!
All RockShox did was take a Rev and make it wider - not much development there, and it's been a solid banker for them ever since.
I hope the bubble hasn't burst as I'd like easy access to tyres/cranks/hubs as I continue to ride one over the next 20 years.
Fat bikes are a niche so any non standard tyres such as slicks are going to be a further niche so low production run = high price. I dropped £125 a tyre for the Vanhelgas, studded Dillingers are £225 😯
