Purely decorative.
Turn it round if hub logo alignment is a serious issue for you...
Obviously novice bike owner!
Can't wait to see the car he is getting.
[url= http://www.gumtree.com/p/for-sale/mountain-bike-3-weeks-old-brand-new/1012323668 ]Nearly right![/url]
Traditionally*, any text or logo on the hub should be the right way round when viewed from on the bike. It should also line up with the valve hole.
*for OCD wheelbuilders
I really like that you went to the trouble of MS painting in a little red direction of travel arrow on the photo, it would have been far quicker to just try turning the wheel round...
It's a QR road wheel; you don't even need any tools just opposable thumbs...
Is there now no bicycle maintenance job so minor that people won't resort to an LBS mechanic / internetz advice for?
Being right handed I always prefer the QR lever on the right anyway...
Give him a break he was only asking!!
Edit : possibly 'she was only asking!!'
I would personally flip it round, but then again valve tyre logo alignment bothers me.
It's not doing any harm though
Thread made I smile.
Never mind that, its the stickers on the fork leg and QR you should be worried about.
Actually that's a point does it have correct Tyre logo/valve/hub logo alignment?
What about Headset spacers, do these have logos? are those properly aligned? Is the bar tape applied in a perfectly symmetrical pattern?
If any of these things are so much as 0.15mm out I'd take it back, get all shouty and rude, tell them you're an Engineer, they'll soon do exactly as you demand...
Is the tyre directional? Is it facing the right way?
decorative, but as birky said- check if the tyre is directional.
but cookeaa has a point too ๐
It is worth a check all over, bar alignment, are the hubs/headset correctly adjusted, enough grease in bearings if cup and cone? I'm not recommending a complete strip down and rebuild, although thats what i've done before on new bikes when the hassle/time of going back and moaning is far greater than a little of my spanner time, but just a check that its not a fri afternoon build....
Surely a troll? The direction arrow is a masterstroke.
If not, the mechanic probably put the tyre with a single sided logo on the wrong way round by accident and flipped the wheel round so that they'd both be on the same side.
i'm going to flip it around so it matches the back hub
You can't do that.
The front wheel has to be opposite to the rear. It's due to the fact that front wheels experience differing forces to the rear - braking rather than accelerating in this case.
You may suffer a horrendous accident, and almost certainly random people are going to point and laugh at cafe / pubs stops.
Don't forget to also turn round the tyre and inner tube.
You do have directional inner tubes, I assume? If not, best to get back to the shop for a full refund.
also swap the brake pads over. as they have bedded in on the rim
No but it is upside down.
Bearings work 24% better spinning clockwise.
Now y'all play nice, y'hear?
could be genuine... ๐
triple post....
do i get a prize?
Don't do it!!!!
My mate did and it led to prompt catastrohpic failure that almost cost him his life, months in hospital. YHBW.
You're in no position to take the piss as you regularly start "should I go outside today" type threads! ๐
njee20 - Member
Indeed but when someone has made up my mind for me, at least my wheels are rotating in the right direction. ๐
That's more of a worry as it probably means they haven't set up the front mech.
Which means they haven't turned the cranks.
Which means they probably haven't set up the gears at all.
So you will almost certainly be killed.
I love threads like this. ๐
That's a job for your lbs
Mtfu
Sue them
Suck it up, etc, etc
