i've just taken delivery of my new toy(2010 merida 901 18sp)and i'm finding the bar tape really uncomfortable on longer rides.
any suggetions as to what's good to buy would be greatly appreciated.
thanks in advance. adey
MTFU
wish i could, but my hands are my job ๐
try specialized bar phat with either 2.5mm or 4mm thick silicone pads under the tape. mmmm comfy.
Another recommendation for the Bar Phat stuff from Specialized. I'd go for the 2.5mm padding personally as the 4mm one really is PHAT! Can actually be too much if you've got small hands.
I use it on my cross bike, it works wonders at damping down the vibrations.
You could double wrap it. I believe the pros do for the rougher classics.
[i]my hands are my job [/i]
So much potential here... I'll start. Do you play the trombone?
How do you mean by uncomfortable? Do you mean the surface of the tape (i.e. it's rough, lumpy, whatever) or that riding on bar tape with a rigid fork and a front tyre at 120psi is painful?
The former, just wear some gloves.
The latter, just, er, wear some gloves.
I run tyres at up to 140psi on my good bike, and only wear gloves in the winter.
MTFU indeed.
๐
+1 for the Phat bar tape. What I've done is put the pads on the tops and around the hoods area, but not on the drops. It does add a bit of weight but is worth it in my opinion. The tape itself is good quality too.
The advice above is good - there are other makes of under bar padding also. 4mm could be too much, and add to the discomfort if you have small hands.I'd also change to cork tape if you've not already got it. On mine I just have a simple strip of tape along the top of the top of the hbar (not underneath) then wrap as normal - its amazing the differnce such a small amount makes.
You could try gel cork tape chain reaction has lots of options.
Oh and move you hands around more, you've got lots of places to put your hands - use them.
