Handle bar mount fo...
[Closed] Handle bar mount for Memory Map GPS ?
Is there anything apart from the Memory Map version fro £20? Reviews state its a bit fragile, its for an Adventurer 2800.
Posted : 29/11/2013 9:39 am
 Esme
I already asked [url= http://singletrackworld.com/forum/topic/universal-bike-mount-for-gps ]this question[/url]! However, the problems I'd encountered were because I was also using the extended life battery. The mount for the [b]combined[/b] unit is not secure enough for MTB, in my experience.
Since then, I've just used the Adventurer 2800 by itself, and the mount is absolutely fine. And the battery life is also good.
Posted : 29/11/2013 10:36 am
Ok ta. Out of interest, how long does your battery last ?
Posted : 29/11/2013 10:58 am
The supplied MM bracket is worse than shi7e, mine wobbled about so much I couldn't see the screen properly, then it snapped and fell off. I bodged it back together with a different stem clamp and it's a lot better but wouldn't recommend buying one at all.
Posted : 29/11/2013 11:16 am
 Esme
I don't actually know, Scruff! But it's more than adequate for a 4 hour ride. I'm just a bit paranoid about battery life, after endless problems with the Road Angel.
Whilst the extended battery pack caused problems on the mount, I now carry it in my backpack "just in case".
Posted : 29/11/2013 11:20 am
I usually get 4 or 5 hours from my standard battery, but I don't tend to faff about with the screen too much as that makes a big difference.
Posted : 29/11/2013 11:22 am
 Esme
It's interesting that you've had problems with the MM mount, Fatboyjon - especially as it's actually a RAM mount, highly recommended on the [url= http://singletrackworld.com/forum/topic/universal-bike-mount-for-gps ]other thread [/url]. So I'm not sure you could buy any better.
That said, I've not tried the original "stem clamp", as I asked MrEsme to [s]bodge[/s] manufacture a more permanent fixing. Not because of any problem with the original, just me being a bit paranoid after earlier problems with the combined unit (GPS plus extended battery). I'm really happy with the current set-up.
Posted : 29/11/2013 12:21 pm
