Humour me here. Just bought a cheapo DH bike off ebay with an 8 Speed cassette (assuming everything else is 8 speed too - cant even remember last time I used 8 speed stuff).
Im assuming if I throw the XO cranks w/ 10 speed chainring on it then the 8 speed chain s going to be way wide for the 10 speed chain ring and thus slip all over the place?
Where's it going to slip to?
It'll be fine, 8/9/10 speed all have the same internal width chain.
I use 7 speed on my commuter - with a retro dx thumbie... it's the most reliable set up out of all my bikes, and it's the most neglected.
Thick/thin? No idea, doubt any one's tried it!
I'm running a shimano zee crank with a 36 ring on an 8 speed cassette & chain on my DH bike without any problems.
You only get into problems AFAIA when trying to run a chain thinner than the rings, so a fatter chain shouldn't present any issue.
Cheers, Rich
Cheers! I thought I was probably having a blond moment. In further inspection it appears to be a 9speed chainset, chain and shifter and an 8speed cassette. Go figure.
It'll all get swapped out for some shiny 10 speed gear at some point im sure!
