I think it looks good! It'll be interesting to see what happens to the concept in the future..
Hammerschmidt...
There's a product I don't hear people talking about too much these days, I thought it was the future of MTB?
I think even SRAM have given up on it.
Interesting but there are enough similar sized people knocking out full gearboxes that I really can't see much demand for this
It's a very cool looking concept but that prototype looks like it's been stripped off a WWII tank found in a bog somewhere.
Not sure it's needed, is it? A Rohloff already offers the same spread as 3x9, doesn't it? More or less?
8 speed Alfine is about £150, Rohloff is £900. Assuing they can bring this in under £750 it's looking promising.
I thought the big market was with a rear a standard multi speed cassette but allowing use of a chain device?
NO NEED!
1 X 10 all the way.
32T chainring with a 11-36T cassette is perfect for trail centre riding IMO.
And when 11 speed cassettes hit the market, at a guess 36T chainring will be even better IMO.
No need for any heavy gearbox nonsense, just something else to go wrong.
NO NEED!1 X 10 all the way.
Gearboxes could keep all the gubbins out of the way of mud and rocks though, in a way that 1X10 doesn't. And make for better weight distribution than a Rohloff.
Gearboxes are definately the future. I'm not convinced they are the present but it's nice to see people giving it a go.
well there's your limitation, right there.
I've been riding a Rohloff for 4 years now. /once you learn to cope with the different weight distribution, the advantages are immense.
I've also had an alfine-8 which was good, but nothing compared to the Rohly, and still ride SS also.
2 and 3-stage BB/crank mounted gears could be useful if they're cheap enough to be combined with a cheaper hub-gear. i remeber people talking about combining the Hammershmidt with an Alfine. Sure it gives the spread of gears of a triple setup, but for the cost and weight of a Rohly with added complexity. And sadly Shlumpf drives aren't uch cheaper.
Most exciting thing I've seen is the Pinion gear-box. Would love to give one of those a go. especially on the Nicolai they've built for it. If only they could figure out a way for a concentric main pivot, then it could go belt-drive too.....
Edit - just watched the video again. Massive advantages for city bikes, and could realistically replace a triple chainset [b]if[/b] its cheap enough....
even my weedy legs can outsprint a 32-11 combo, needs to be bigger imo
ir - where are you based?
Love my HammerSchmidt, proper spread of gears for proper mountain riding.
This looks interesting.
Bencooper....can I rent your schlumpf tool for a couple of days pleeaase? xx
The mitring one? Sure, as long as you give it back unlike the last bike shop I lent one to 🙂
Ianpinder - I'm in Northumberland. How's your Pinion?
As much as I like the pinion I think the effi-gear will be better once it's in full production
And they have it demonstrated with a belt drive
