half fat tyre psi
[Closed] half fat tyre psi
[#3513365]
I'm running a half fat on my 29er and was woundering what psi others use front and back please
i,ve been using around 12psi on front and in my 2.3 on the back i'm using around 30psi
thanks
Posted : 02/01/2012 2:46 pm
about 4- 5 psi in a nate on the front and about 25 ish in an ardent on the back
Posted : 02/01/2012 3:03 pm
I used 8psi on the front with a Larry. Ran the back at its normal pressure.
I've just fitted a Nate and I can see how it may benefit from an even lower pressure because it feels stiffer in the squeeze test. For now I'll use 8psi until I have tried it out for longer.
Posted : 02/01/2012 3:31 pm
About 5-6 in a Nate a bit more in a Larry.
Posted : 02/01/2012 3:33 pm
