H adapter not long ...
H adapter not long enough for hope v4s and 203mm rotors. Wrong adapter?
 jsm
Hi,
Can someone check me here? 2024 fox 36s with hope v4s, need a H adapter? I've just fitted them and the 203mm vented rotor - even without the pads in, they need a small shim between the fork and the adapter to increase the space for the rotor.
Is that normal?
Ta,
Stu
Posted : 21/08/2025 6:54 pm
I have the same brake and fork, with 203 (non-vented) discs and all fits fine. Is the arrow on the adaptor pointing up?
Posted : 21/08/2025 10:46 pm
Did you have the fork from new? Has someone faced the post mount?
Posted : 21/08/2025 10:49 pm
Not been sent an L in error? ย
Posted : 22/08/2025 7:26 am
I have this issue with my Hope V4's with 203m vented V4 rotors on Fox 38's & 36's also on the frame itself (Spesh Levo)
I run a thin washer between the H adaptor and the brake caliper body, don't run one between the fork and the adaptor as ideally you want a nice flush connection between those two
Even on my Transition Spur, the rear needs a small washer between the adaptor and the the Hope E4 caliper to make the Hope 180mm normal rotor fit, the Fox 34 fork is fine and needs no washers between the caliper and adaptor for the 200mm rotor to fitย
Posted : 22/08/2025 8:15 am
 jsm
Thanks everyone. I also have an old set of L adapters, so I can tell the H ones are bigger. The forks were from new.ย
Posted : 22/08/2025 9:06 am
