GXP or HT11 into BB...
[Closed] GXP or HT11 into BB30 anyone done it?
Need to do mine, what do you recommend. GXP SRAM into BB30.
Posted : 24/12/2014 5:24 pm
Just push one of these in and use bsa bb's (I've fitted almost every option at some point)
Posted : 24/12/2014 5:29 pm
Did you bond it in?
Posted : 25/12/2014 5:50 pm
You get some bearing fit with it.But it's an interference fit.You'll need at least a headset press to do it (check the frame has removable c-clip/rings and not a step in the bb.And remove the cable guide screw first!!)
Posted : 25/12/2014 6:00 pm
I think the FSA one comes with a sachet of loctite, at work we use tri peak adapters that we press in then use normal ht2
Posted : 25/12/2014 6:02 pm
Ahh
Mines a 853 Steel frame, no clip assembly so probably stepped.
Posted : 25/12/2014 6:38 pm
Panic over, it's BB86 far simpler. Standards huh!
Posted : 25/12/2014 7:53 pm
