Sixc crank, Raceface 32t chainring.
Just gone from a 36/24 double to 32 single and the chain looks a bit too close to the tabs for comfort.
Could space the chainring off a bit but don't want to crack the tabs (carbon). Would rather not go up to a 34t but then again I don't want to ruin the tabs.
Any thoughts from the STW massive?
P.s. Tried a 32t narrow/wide on and tbh it's a tad closer.
Can't see a problem to be honest, my 1x10 set up is the same. I'm running an XT crank with a Renthal 32 ring and it looks the same.
If you decide to run a 30t they are stepped in slightly to avoid catching the tabs, and the chainring bolts screw directly to the ring.
Here's a pic of mine (ring was a Blackspire NW but now Renthal):
Edit: I'm also running a carbon crank on my Hardtail with a 32 ring (1x10) and its exactly the same.
No issue there for me. Looks spot on
I wouldn't worry about that.
Running a race face 30t narrow/wide on a set of sixc cranks, clearance is ok as long as I keep the chain clean.
Cheers lads, was just worried about the chain chewing the plastic tabs away.
jes - Member
How do you find it runs with not having the tabs sandwiched between the chainring and the metal support tabs? Fancied spacing it but was worried about the load all being on the spacer.
Or am I thinking too much as usual?
So long as it's not actually touching you should be fine. Even if it is touching it probably will be ok. Will just wear them a bit.
