Going to a 'superbu...
[Closed] Going to a 'superbuild' bike ? Would most mortals notice ?
Got my 50th coming up in 18 months, plan was to get a KTM 1290SDR, but now i have a new KTM790 i don't feel that need any more. By then, I'll have been on Whyte T130s for over 4 years, so maybe thinking instead of jumping onto a super bike. As for the 'what' i honestly have no idea. But thinking for example something like a Yeti/Santa Cruz etc.
Most of my riding is fairly tame, but every now and again there's things like a BPW, Afan, or even a Morzine. My T130 fills me with more confidence than i can possibly imagine, i never ever feel i'm being held back by it, more the opposite.
But would someone at my sort of levels even notice ? Gear wise, i'm really not bothered running 10, 11, 12, i don't feel i need more (or less) gears than a generic 32T front with a 36 cassette. But things like a set of Fox 36s, a CCDB shock and 2-3Kg lighter,would you notice ?
Posted : 15/05/2019 9:03 am
If you want it, and can afford it, get it.
Or buy an ebike. 🙂
Posted : 15/05/2019 9:15 am
Personally I see too much bad press about Yeti frames and warranty so out the two options you mention I’d steer towards Santa Cruz.
I think you’d notice light wheels more than the light frame, and probably a stiffer but plusher fork over fancy drivetrain components.
What do you want your new bike to replace - the t130? If so what would you like it to do better - it’s a good bike but maybe not the most efficient at pedalling and a bit heavy. Has t got enough suspension travel for you or are you looking for more?
Posted : 15/05/2019 9:17 am
Or buy an ebike.
Seeing my mate (Couchy on here) flying on his, it's bloody tempting at time. But i'm not prepared yet to go down that road.
What do you want your new bike to replace – the t130? If so what would you like it to do better – it’s a good bike but maybe not the most efficient at pedalling and a bit heavy. Has t got enough suspension travel for you or are you looking for more
I doubt i'd keep the T130 no. I feel it has plenty of bounce for me, as i say, i don't think it's holding me back at all. But it's a bit 'Ford Focus' in some ways isn't it, middle of the road, decent enough bits, but all fairly budget to an extent. Nothing really stands out as 'wow' in the specs of it. But i don't think I'd go for it just for the sake of it, i'd like to ride it and think "WOW that's amazing", whether that translates to Strava times up, or down, i don't know, or just plushness, comfort, etc. The bike needs to be a Do it All type bike, like the T130 is for me. I've got things like the Ridgeway 55 miler this weekend, the SDW later in year, but also BPW and Morzine, so this one bike has to do all of them pretty well, hence where the T130 has generally been brilliant.
Part of me is thinking "Why not just get the best T130 in the range?" and in honesty the only thing that's lacking in is the 'new' factor. It's the same of the same as my last 2 FSers, but they're awesome and i do love them.
Posted : 15/05/2019 9:24 am
I'm going through a similar thought process and basically just like new toys.
Just built up a carbon Chameleon and am amazed at how well it rides, although it was only supposed to be an alloy frame and second to the Ibis I ordered back in February.
As I still don't know when the Ibis is coming, I decided to spend too much on the carbon sc frame and glad I did.
How about something like the new Ibis Ripley with a fancy build? (I've gone for a Ripmo - don't need it at all and most certainly won't ride to it's ability but, **** it why not :o) )
Posted : 15/05/2019 9:26 am
Go for it. Also if you’ve got 18 months to go then if you get a move on, by the time you turn 50 it will be time for another upgrade!
Posted : 15/05/2019 9:30 am
I think at some stage i need to get to a Demo Day somewhere, just to ride a few of these types, be it an Ibis, a YT, SCruz, whatever really, just to see if they have that WOW to ride. Sure i understand that over time the wow will turn into a normal and it will just then become my bike, but i'd like to start with the wow. Certainly would make sense to do a day somewhere and try 3-4 different bikes.
Posted : 15/05/2019 9:31 am
There'll be at least 5 new 'standards' and things may well have moved on a bit in that time.
Probably a bit early to be thinking about 'what bike do I want next Christmas' I think..
That said, if you like the Whyte, why not get another bike more suited to the tamer stuff and kit the Whyte up for the rad-er stuff?
I think then as an all out super build I’d go Santa Cruz Branson CC, with a Pike Ultimate, RS Super Deluxe shock, 11 speed xx1 drivetrain but with a Dub crank and BB, DT XM1501 wheels, Maxxis tyres, Sram Code RSC brakes, then whatever light and fancy looking but durable dropper / bars / stem I could find and Raceface grips. Would want it to come in sub 30lbs and pedal ok but be capable on the downs. Think the Nomad would be too much of a steam roller.
Posted : 15/05/2019 9:35 am
That would start getting into too many bikes and too much cross-over really then, i've got the HT PArkwood if i need a 2nd bike, 29er so fills that, it also doubles as my turbo/zwift bike, to go in the 'tamer' category i'd be looking at a light 29er short travel FS, like a Scott Spark for exmaple (or is it the Scale, i forget lol) but either way, i'm then riding one bike lots and 1 of them hardly ever... So starting to lose the point of it really.
Posted : 15/05/2019 9:46 am
I got a WOW when I first rode a carbon 5010. Got one, it’s specced up to the nines, weighs bugger all and still amazes me how good it is, 5 years on. As tech has improved (longer droppers, moar gears) I’ve changed bits, but fundamentally its the same bike.
No sure if you’d get that as much, as others have caught up a bit now, but I’ve ridden plenty of other stuff since getting the 5010, and nothing has given me that same ‘this is waaay better than anything I’ve tried’ feeling.
Posted : 15/05/2019 9:56 am
My buddy just picked up a really good spec '18 Santa Cruz Nomad for from a shop for £6k-ish, didnt think the carbon everything and other high spec parts would mean much of a difference, he now flys on that thing and we werent slouches before! not sure what it is but the bike just goes forward for no effort, thinking its the carbon wheels and good frame design. Making me consider carbon wheels so I can keep up!
Posted : 15/05/2019 10:04 am
If it was me I'd go for the T130 C Works 2019.
It'll be familiar but lighter, faster, tad more travel & modern geometry.
You'll definitly notice a difference. Any change can go to a holiday riding it in the Alps.
Posted : 15/05/2019 10:06 am
I've had 'super' bikes in the past, an ibis mojo HD with all the trimmings, and imo they're not substantially better than a much lower speced bike, the law of diminishing returns definitely applies, but if you want it and can afford it then get it. But don't expect some hugely better ride.
In terms of areas that make the most difference to the way a bike rides my list would look like this, going from most important to least, and is based on the views of someone who like going downhill, but doesn't care if uphill is slow.
- frame geometry
- rear shock
- forks
- brakes
- tyres
- all the above are quite close and you could swap them round in order, but there's a massive gap to the next things down
- frame material (carbon/alu etc)
- drivetrain
Posted : 15/05/2019 10:07 am
The problem with super bikes is that once they are couple of years old, whilst some people still look and say "nice bike mate", you then see someone on a brand new one and suddenly you're the one saying it and getting jealous. Especially when he drops in and sends a massive effortless whip. Or worse tells you, you can go first........
Posted : 15/05/2019 10:16 am
Save your money - it won't make any difference 🙂
Posted : 15/05/2019 10:28 am
I personally wouldn't just get the same as what you have but in a super spec'ed version. Eventually those components will wear out and then you'll have the huge cost of replacing them or reverting to cheaper comparible components and then what was the point? For example if the super spec version comes with xx1 eagle you will not want the costs of replacing that chain and cassette like for like each time.
I would think the biggest difference you'll notice is a completely different bike perhaps in carbon if you'd like to feel the difference of a bit of weight saving. I don't think you'll notice a ride difference between carbon and alloy.
MTBYumYum has had some really great stuff to say about the Ibis Ripmo he's been out riding lately. I demo'd the Ibis Mojo HD4 and it was a huge bike and actually pretty dullsville. You could always take a slightly different approach and get something less mainstream too. I also demo'd a rocky mountain altitude and flippin loved it but the riding style I enjoy may not be the same as what you enjoy.
You could always get an ebike and keep the Whyte too? For days when it's just you and you want to explore further and do more laps than you can now?
Posted : 15/05/2019 10:31 am
I did the same. S Works Enduro 650b, even sent the frame back as it was the wrong colour. Built it up with Lyriks, Ohlins, X01 eagle, LB carbon wheels and Saint brakes. Most of it stealth black and carbon. Felt great every time I threw a leg over it.
Due to logistics I spent most of last summer riding the 29er version of which I hated the colour but the ride felt more like me.
Last time it was rode was in Pila last year by my eldest daughter, its slowly moved to the back corner of the garage so its probably the right time to strip and move on.
Its always nice to treat yourself, go for it.
Posted : 15/05/2019 10:32 am
 Yak
weeksy, ah - you just missed the QECP Cyclefest with demo bikes all weekend. Anyway, try and find a demo day somewhere. Will you notice? Yeah, definitely. You will rule out some good bikes out too, and there maybe will be the 'one'. But that 'one' might not be a santa/yeti/superwhatever. It might be canyon, trek or a whyte again. But you will know then whether the itch needs scratching.
Especially when he drops in and sends a massive effortless whip. Or worse tells you, you can go first……..
That's not a world in which i live... I'm more than aware of my place in the world.
Posted : 15/05/2019 10:45 am
i’d like to ride it and think “WOW that’s amazing”, whether that translates to Strava times up, or down, i don’t know, or just plushness, comfort, etc.
If you spend the money, you'll get something just as robust that weighs a bit less. It might even be a bit stiffer here or there, but as you've obviously realised your current bike is pretty decent - middle of the road etc. and not blingy, but solid all the same. Whether it'll make you noticeably faster or even more comfortable - well this makes me think you could end up a bit disappointed. Any extra plushness will just be that your forks/shock could currently probably do with a service.
A lot of the benefit of more expensive suspension comes from more adjustability, which if you're quite happy with how yours descends I doubt you'd use/notice (not a reason not to, as I said everything will be a touch lighter so that's always nice).
If you don't spend it on a bike, why not spend it on a (big) holiday?
Posted : 15/05/2019 11:01 am
If you don’t spend it on a bike, why not spend it on a (big) holiday?
Indeed, although not big in some peoples world the other option/possible/likely is a trip to Andalusia with David. https://bikingandalucia.com/
We've done one of his trips before and absolutely loved both the place and the riding, so as my lad will be 12 by then we're considering 2 weeks there (1 week guided) for it as well (or instead). We could wangle it so instead of my lad doing all the road based climbs he could get uplifted by the wife in the hire car in the mornings and then he does some of the climbs for the rest but also plenty of the downhills.
I've swung the idea by my riding mate who'd be with us and he seems up for that too.
Whilst some here may not think that's a wonderful trip in some ways, it really would be in my world, it's what i do and love, so would suit perfectly, especially as we could get Mrs Weeksy there too with her then having a week of exploring and pool stuff while me and the boy are riding.
Posted : 15/05/2019 11:17 am
The weight is the most significant part tbh. A 28lb XC bike vs a 22lb one seems to make far more difference than the numbers suggest, purely in terms of feel. And the feel can inspire you to push on more on climbs and throw the bike around more quickly on the descents.
I haven't used proper top end advanced suspension, but I can imagine that stuff like CCDB shocks would make a noticeable difference on descents in terms of feel. Whether or not that translates into extra speed and if that translates to extra fun is anyone's guess. I've had top end bikes before, when I had more cash, and they were way worse than my current medium bikes due to technological improvements in suspension, geometry and yes, wheel size.
My current three MTBs to replace for similar stuff would probably cost £7k ish. But I'd FAR rather have three diverse mid range bikes than one top end one. No question whatsoever.
Posted : 15/05/2019 11:19 am
There’ll be at least 5 new ‘standards’ and things may well have moved on a bit in that time
A common misconception. My Bronson is just over 2 years old now, and nothing on there is obsolete.
Posted : 15/05/2019 11:40 am
Tbh, thinking about it, I've similar feelings about the Bronson as you do about your T130, dunno if there's anything that would be any better, noticeably. If I had the money sitting, I'd be buying an Ebike, specifically the YT Capra.
Posted : 15/05/2019 12:00 pm
I agree with this:
"– frame geometry
– rear shock (edit: and tune/kinematics of the bike)
– forks
– brakes
– tyres
– all the above are quite close and you could swap them round in order, but there’s a massive gap to the next things down
– frame material (carbon/alu etc)
– drivetrain"
And wheels I just want rims that are fairly wide, stiff and strong without weighing as much as the moon (so plenty of alloy rims meet that) and hubs that are reliable.
Both my bike builds meet these criteria, the e-bike is a bottom model alloy one with fancy forks, brakes and dropper (amazingly the stock shock works really well for me) and the hardtail has Pikes, Hope brakes, GX Eagle and Hope/Stans wheels.
Uphill I guess I prefer lighter bikes but I've never noticed much difference. Downhill I prefer heavier bikes.
Posted : 15/05/2019 12:06 pm
I'm not seeing any value in an Ebike myself. I enjoy and want the work. We can sit and discuss the why/how/benefits/etc all we want, but an Ebike isn't in the discussion at all.
Posted : 15/05/2019 12:08 pm
HB130
Posted : 15/05/2019 12:10 pm
"I’m not seeing any value in an Ebike myself. I enjoy and want the work."
They're pretty weird. You get back on a normal bike and think "why am I going so slowly?!!" I guess some people might get on a normal bike and think "why is this so much effort?" but I enjoy pedalling and enjoy going fast!
Posted : 15/05/2019 12:11 pm
There's nothing inherently better about the bikes from the more prestigious brands. An 8k Yeti/Santa Cruz isnt necessarily better than a similarly spec'd 5k Canyon/YT.
Diminishing returns is true as well. I personally don't care for the benefits of an XX1 Eagle over the GX and I bet most wouldn't be able to tell in a blind test. Having said that there are areas where I won't compromise - geometry, suspension, brakes, tyres.
If you want something that wows you how about something with more travel for those Morzine and BPW visits? If you go mid-range (or direct-sales) you might have some cash left over to ride those places more and upgrade your Whyte too (upgrading components one at a time is great for reducing N+1 bikes syndrome!)
Posted : 15/05/2019 12:13 pm
The Hope HB130 and Forbidden Druid would be very high on my like of potential "superbikes".
Posted : 15/05/2019 12:15 pm
Not really a massive factor currently as i'm generally riding them with my 10 year old, who's not at my pace yet, so any rides i' still waiting for him and going at his speed. It's a swings and roundabouts thing as i don't get to push 100% of my skills/speed, but on the plus-side i get to ride these places with my son, which is fantastic.
But even if i went on my own, i'm not convinced i have the skills to justify a bigger bounce bike, or indeed the desire ! We're both at Jedi in Aug, so don't say "Do skills day" as we're doing that.
I know it sounds like i'm not helping in many ways here LOL. But i'd like to see a tangible wow as i say, i'm not getting the impression i'll end up with that much of a wow and adding in a 2nd week in Andalusia may end up making far more sense than anything else.
Posted : 15/05/2019 12:19 pm
This. My 5010 is 5 years old. Apart from boost, all its standards are current, and no one is releasing hubs in boost spacing only yet.
Posted : 15/05/2019 12:20 pm
I built up a fancy road bike once, thinking it would scratch an itch but in the end it didn't feel like 'me' and I ultimately sold it to be replaced with a mid-range cx bike which got a load more use.
Undeniably, nice bikes are nice to have just for the niceness of the thing let alone the pleasure of riding it... but I feel like the quality of even mid range stuff nowadays is so good that it means you are getting less and less return for your increased investment and higher replacement costs like-for-like if something breaks. It also feels worse when it gets scratched!
The holiday plan sounds good to me but if you were going to get some new bike then in your position, I'd get a new bike different to one that I had, not just a better version.
Posted : 15/05/2019 12:23 pm
My current three MTBs to replace for similar stuff would probably cost £7k ish. But I’d FAR rather have three diverse mid range bikes than one top end one. No question whatsoever.
This - road bike to get fit on, cross bike for racing, XC bike for well XC, gnarpoon for the mountains ... more variety = more riding .. less crying when they break / get nicked.
Posted : 15/05/2019 12:27 pm
I'm not sure the question is whether you'd 'notice', I'm pretty sure you would, it's more whether a flash new bike would make an enduring difference to your enjoyment of riding. I suspect it varies according to individual wiring, but for me at least, provided the bike is half decent, it's more about the riding than the hardware.
So... I spent a day with a mate riding a borrowed Trek Full Stache, for example, and while it was highly amusing and super capable, I don't know that I had any more fun that I would have done on my humble Sonder Transmitter. Maybe I had less fun. I was certainly faster, but that's not the same thing.
I'd have enjoyed the trails and the company and the scenery and the sensation of riding on pretty much any half-capable mountain bike. As above, I'd rather spend money on riding new trails abroad or in the UK, though I get the thing of buying something concrete on a significant birthday. Maybe you could go part way by investing in a cool upgrade for your current bike rather than spending exponentially more on a whole build.
weeksy, ah – you just missed the QECP Cyclefest with demo bikes all weekend
Yes, Santa Cruz, Transition, Cannondale, Spesh - all brands to be considered in the super-build area.
I demo'ed a Scalpel, short travel, but by heck that thing was fast. 9Kg and 9K£ 😆 Yes, I did notice that it was a very expensive bike. It still creaked like a bastard though! (BB I suspected).
(Also demo'ed ebikes and they are definitely something different)
What about Evil? Pivot?
Need to demo, that's fersher.
Posted : 15/05/2019 12:31 pm
Surely there's an argument for buying the best hike you can afford. But that doesn't mean the most expensive.
Plenty would argue that what Geometron, Pole and Bird lack in carbon fibre they make up for in geometry (although the former two make up for it with carbon-esq superbike price tags.
Conversely if the geometry suited you then the Vitus Escape vrx comes with factory 36's, dpx2 shock, etc for less £££.
Good design doesn't nessecerily cost more money, it might even save it. But Id not get hung up on Yeti/ibis/SC when YT, Commencal, Bird or Whyte might make a better bike (either in general, or just one you prefer).
Posted : 15/05/2019 1:02 pm
I rented a Pivot switchblade for a day once. AT the time I was seriously considering buying one. It was a ded posh megabike, carbon cranks/wheels, top end Fox36s n'shit
Really didn't like it though I'm not clever enough to say why - the shop "set it up" for me and so it should've been OK from that PoV. Tested a Bird after that and ended up buying a frame at maybe a third/quarter of the cost of the pivot
Prior to that I'd have said that I never demo bikes or frames that I buy but that changed my mind, at least for spaffing big money on one. (wanted to try a Trek too but turned out to be near impossible to arrange - I guess that's what you get with niche brands 🙄 )
Posted : 15/05/2019 1:04 pm
I did a demo day and tried a Whyte and Orange full sus. Were much of a muchness with my Salsa Horsethief at the time
Then I had a go on a black edition Cannondale Trigger. It was phenomenal! So light and easy on the ups and floated back down the hill like a magic carpet.
£7k mind....
I think you could get a "superbike" that's a couple or three years old and get good "this is better" for the money
Posted : 15/05/2019 1:13 pm
I did this the last time I got a full suspension bike - I went from a Commencal Meta AM with XT 1x11, Pikes and some entry level Mavic wheels to a carbon Transition Patrol with full XX1, carbon cranks, Chromag bits and DT Swiss wheels. I did buy it almost entirely secondhand, so it cost about £1800.
It is definitely better than the Commencal. It's more capable in all areas but pinpointing why is a little difficult - it's lighter, because the bits are fancy, which means it feels better climbing but also fatigues me less over the course of a ride. The geometry from a lot of the boutique brands tends to be more progressive than the bigger companies, and this was definitely the case with the Transition. That makes descending really enjoyable, it's very capable.
One big advantage of it in terms of cost is that I've not been tempted to change it - normally after a few years on a bike I'm tempted to swap it, but this is still such a nice bike, and still pretty current in terms of standards and geometry, I'm happy to keep it. And the fancier bits are lasting well. The XX1 cassette, which I got second hand (it was about 2 years old) has only just died after 2.5 years.
If you can afford it and want to do it then do so. But if you just fancy a new bike and can't justify spending mad money on one, just see what's out there that takes your fancy for normal money. It will be almost as good, and certainly not several thousand pounds worse. It's hard to find a bad bike these days, and ultimately, when I'm going down a hill, I don't think about the fancy shifters or cranks and just get on and ride the thing.
Posted : 15/05/2019 1:15 pm
Should i go down the road, i'm far from hung up on the boutique brands, I was looking for example on the Specialized concept store and love this.
https://www.specializedconceptstore.co.uk/product/12046/2018-stumpjumper-expert-650b/
But i'm pretty sure it's not giving me much over my current T130.
But then if i were looking today, i'd struggle not to see something like this Whyte
https://winstanleysbikes.co.uk/bikes/mountain-bikes/full-suspension-mtb-bikes/whyte-s-150-c-works-29er-2018-bike
or this one
https://winstanleysbikes.co.uk/bikes/mountain-bikes/full-suspension-mtb-bikes/whyte-t-130-c-works-27-5-inch-2018-bike
But i'm thinking at the moment "Hmmm really... is there much point in it...." and the answer is, i don't really know.
I could offset part of the plan assuming my lad is growing at the rate he currently is by throwing him my T130, which would save me a chunk of change instead of buying him a new bike.... But now i've gone to a large, he may need to grow more before that became viable. It would also depend on whether he's still as into the riding as he is currently. So many thoughts, so many ideas. LOL
Posted : 15/05/2019 1:16 pm
+1 on the buy a new bike, but spend the 'superbike' change on a holiday...
You're definitely on diminishing returns.
Yes, get good stuff ( I can tell the difference between my son's Pike and my Yari, his XT brakes my Desire brakes).
I've also tried (but never owned) properly posh bikes, and frankly they weren't really that much faster, more comfortable or blingier when covered in mud...
Posted : 15/05/2019 1:19 pm
Test loads and buy the bike you love to ride the most.
Posted : 15/05/2019 1:28 pm
I was in a similar position, 46yrs old and had a £3k Santa Cruz Tallboy for four years and had an itch for something fancier. Tested a few bikes (Santa Cruz highball and Blur, Orange stage 4, Yeti SB100). Went for the Yeti in the end as it felt more trail vs the XC feel of the Santa Cruz's and I loved the bottomless feel of the switch infinity. Ended up spending more than anticipated, but put it into good forks/wheels. It is definitely more capable than the Tallboy, but definitely not a huge leap.
Posted : 15/05/2019 1:33 pm
You were def at 100% at BPW when I was following you on the ebike 🙂
You like the bike you have so keep it, save the money for an ebike in a few years when you're old like me 🙂
Yes but that was 1 run... I was at 100% at Swinley the other day too (setting 91 Strava personal trophies lol) but these times are very few and far between as i can't just abandon the boy. I still think it will be a while before i'm at 100% to stay ahead of him 🙂
LOL i'll not be allowed an ebike until after 60. If Crust can still do the big boys rides without Ebikes, then until i reach his age, i'm not having one 🙂
Posted : 15/05/2019 1:37 pm
I find if I think about it too much I can talk myself out of anything. Been contemplating a 2019 Stumpjumper for a while for us all to use, shall we shan't we on a weekly basis. Only needed the frame, as we had all the other bits, but a full bike could be had for the same price as a frame and decided not to get one.
Saw a frame on Pinkbike which was at a very good price for the frame which tipped the balance so a 500 mile round trip to South Wales to look and see was a no brainer and we came back with it.
Started the build at the weekend and will be out in the Peak with it this weekend.
Posted : 15/05/2019 1:42 pm
Doubt you'd notice fancy pants components past a certain spec level and there's a good chance you won't get on with a set of 36s as you'll find them too stiff for your riding level (making a huge assumption based on your posting history, apologies if off the mark). Posh frames are however nicer to look at and in the case of the few Santa Cruzs i've had they're certainly very well finished compared to cheaper options; paint quality, cable routing etc. Will they perform better as a bike, probably not as there are so many mass market well rounded suspension designs these days. So basically you're just paying for the joy of getting something out the shed that looks really nice. A Nicolai G13 was still, in my eyes, the nicest bike i've ever owned. Every time i got it out it was hard not to admire the perfect welds on the raw alu frame. Just a shame I couldn't get on with it for where i ride, tempted to try one again in the size down this time.
Given you're Swinley way, Pedal & Spoke is in Peaslake and he's got a demo of pretty much every bike in the Santa Cruz range. Have a go and see if you're smitten.
Posted : 15/05/2019 2:21 pm
I make no qualms about my riding, i have no issues with who and where i am in the big picture. I'm happy at Swinley, happy at anything blue and some reds at BPW, but start going past that and i'm ending up lying on the floor looking at the sky 🙂
Posted : 15/05/2019 2:27 pm
Order a bike off SICK!
Then..
Send It.
(back)
Posted : 15/05/2019 2:48 pm
I was going through a similar thought process this year . I owned a bird aeris and a Solaris which I was pretty happy with all round but I’m turning 40 next year and I have wanted a Santa Cruz since I was about 16  but I also really want to go abroad with my bike and I knew I couldn’t stretch to both  . Then everything got pinched out the garage and I was left an insurance payoff which would of got me the Santa Cruz but I ended up buying a flare max and pocketing some cash for a trip hopefully to spain next year .
The other part of it was I’m a bit of a sucker for British brands these days , infact if Iwent down the super bike route now I’d be thinking of a fancy spec on a Cotic or bird or even something a bit more custom from the likes of starling , Curtis or Stanton
Posted : 15/05/2019 3:36 pm
Other than Kudos , what is you T130 not giving you ?
You don't do bike drop off stuff, like the pure CC stuff more ...
Just by FS carbon scott scale to go with it ...
Posted : 15/05/2019 3:53 pm
Kudos from who ? I couldn't care less about peoples opinions 🙂
It gives me everything, but what i don't know is, if something 'better' would give me more or not.
Posted : 15/05/2019 3:59 pm
 rs
most mortals don't even notice my ebike is an ebike.
Posted : 15/05/2019 4:06 pm
Seems like you're only musing over a flash new bike because of the approaching big 5-0 and there isn't actually anything that you want or that's going to make you any happier! Nothing wrong with that, but surely better to save the cash for a rainy day!
Or how about a couple weeks in Whistler!
Posted : 15/05/2019 4:46 pm
I was in a similar position to you, similar sort of riding, age etc. Really fancied a Tallboy. Got the frame, built it up to a decent spec (but without going mad) and love it. Was going to get rid of all my other mtb bikes - but in the end I also built a light, rigid single speed for blasting around the local trails when I fancy a change. So if you are going to change for the sake of it I would make it the bike you ride the most. Having several bikes that do are or less the same thing seems pointless; bikes seem more versatile than ever. Will it make a massive difference - mostly to your wallet.
Posted : 15/05/2019 4:49 pm
Give you more, possibly not. But I get a massive grin when I work on my bike or walk Into the garage and see it! Not to mention the feeling I get when I ride it. I ride a Ibis Mojo HD4, Fox Factory XO1 eagle Xm1501 wheels. Whilst not blisteringly faster than my old trek remedy, I do find it faster and more pleasurable to ride. In fact better in every sense. Not sure it’s ££££ better, but the money I spent on the mojo was definitely worth it From My perspective. It’s the best bike I have ever ridden or owned. Agree with demoing bikes. My last high end bike was a SantaCruz Hightower. Again top end spec and I bloody hated that bike! Just horrible. I blew a fortune on it and the new owner loves it. So each to everyone’s own.
Posted : 15/05/2019 4:58 pm
Currently riding a Yeti (SB6), previous was another Yeti and prior to that was Whyte.
Keep your current bike and spend the 50th dosh on trips to fantastic riding destinations.
That's what I have been doing since turning 50 (6 years ago) 🙂
Posted : 15/05/2019 5:03 pm
There's lots of parts to your question, most come down to how competent a rider you are.
Would you be a better rider on a Santa Cruz, Yeti, Ibis compared to your T130? Possibly, maybe. Depends which model you go for. Your T130 is a great all rounder but will do things better / worse than many others. On the assumption that you still want an all round capable bike, I'd suggest looking at the Yeti SB130, Ibis Ripley (new one), Ripmo and the Santa Cruz Bronson (which will ride most similar to your T130 of those 4 bikes).
Would you notice a difference with different components? Possibly, maybe. A badly setup Fox 36 Factory GRIP 2 will ride worse than an unfettled Rockshox Pike. Same with a CCDB shock compared to a Fox DPX2. Generally speaking, on suspension, your money goes on more knobs and adjustments so if you don't know whether you prefer more or less HSC and LSR then you may be better off saving the money and paying for a shop to get your setup diallied (or hire a shockwiz).
Wheels and tyres are in my opinion where the money makes a big difference. Something strong, wide, light-ish and with a set of Maxxis Wide Trail tyres. Yes I'd go carbon and I'd be giving my cash to Santa Cruz for a set of their Reserve wheels.
If you're happy on a 32t chainring and an 11-36 cassette, you'll be even happier on an Eagle 32t and 10-50 cassette. More range, less fatigue, more enjoyable riding. Don't fight that trend.
Weight depends; too light and it won't take your alps trip, too heavy and its a pointless slog. I'd go for a sorted frame in terms of geometry, the best wheels you can afford, a well setup suspension platform (Fox 36s are brilliant but they are stiff compared to Lyrics and Pikes and you need to be honest whether your riding needs that).
The bottom line is when it comes to bike brands is there are very few bad bikes these days (and Whyte are up there with the best). If you can get a demo on something top-end, you'll get the best idea whether spending that cash is worth it to you.
Posted : 15/05/2019 5:10 pm
I already own a shockwiz, so within its ability and knowledge my bikes are setup at least half ok
Posted : 15/05/2019 5:13 pm
I demoed a whole load of bikes over the first few months of this year - some chi chi bling (SC, Yeti etc) , some regular rides (Giant, Whyte etc). The thing that made up my mind was one bike that really stood out as being the one that I wanted to go out on again as soon as I got home, that I was actually laughing while riding. Once I had that feeling it didn't matter what it said on the down tube or the fork, I was sold.
So go ride a whole range with an open mind and see if there's anything that you like that much more than your whyte.
I have played with lots of high end bikes over the years and have come back to a titanium hardtail and road bike. Anything else dates so fast and therefore I couldn’t justify spending big on a boutique full susser nowadays.
I am waiting for XX1 AXS to become available as individual components. Until then I am running GX Eagle and as somebody said above it really is hard to justify more.
Above a certain price point the thrill of ownership plays a larger part than a tangible difference in ride quality. A mid range Specialized or Trek will probably ride just as nicely and be backed with better support, but there is something intangible about a boutique parts list that does somehow enhance the pride of ownership.
All that said, as a special birthday treat, why not?!!!!
Posted : 15/05/2019 5:16 pm
I like that Tracy, my current dream bike but those frames are too expensive so I'm waiting for a second hand. Wish they did the normal stumpy in the raw alu or carbon.
Back to the OP
I'd be looking at something carbon from spesh, SC, transition or trek for some reason Whytes don't look very fancy I think it's the awful graphics. Although mine rides well!
Fox 34/36 up front and back. What's so fancy about the CCDB?
Shimano XTR for me, I'd not bother with carbon cranks. Remember you'll only have to replace consumables.
Reserve rims on Hope hubs, your choice of rubber.
Revive dropper and either Hope or burgtec finishing kit.
Then I'd get one of those fancy decal companies to colour coordinate the various stickers and ride!
Maybe some over to buy some decent shorts etc.
As above you wanna make sure you're happy before spending big on the frame.
Posted : 15/05/2019 7:31 pm
It’s also worth bearing in mind that for Santa Cruz/Yeti frame money, you can get some properly custom stuff that no one else will have (as vain as it is, when spending that much, it’s a consideration), even in carbon (around £3.k gets you a custom geo Carbon Wasp FS) or you could go to a small custom builder for something in the metal of you choice.
No way would I buy the most expensive version of something you can get in a chain shop. I wouldn’t buy another Santa Cruz either.
Posted : 15/05/2019 7:57 pm
My work mate has just built up an SB130 - used the XT drive train off his previous bike bought new forks wheels & cockpit.
Stunning bike to look at and he seems to have gone up a couple of gears on his performance - I now struggle to keep up with him.
Posted : 15/05/2019 8:28 pm
I’m normally from the camp of ‘if you can afford it (or afford the credit) then go for it’ camp and the overbiked nonsense doesn’t hold much sway with me. We live in modern time of excess...we’re over - everythinged so bloody what. But, i’ve Test ridden a few super bikes now and always feel underwhelmed. There are some noticeable improvement here and there, but nowhere near enough to justify the price tag. They’re not light enough and don’t perform better enough compared to a non-superbike to get anywhere near being justifiable, they’re just a rip off. Far better spending your money on a wheel upgrade and suspension upgrade.
Having said all that, i’m very tempted by the Forbidden Druid! Mouth-wateringly gorgeous looking (to my eye) and a bit different - i’m Always a fan of things a bit different and quirky. Looking forward to giving one a try.
Posted : 15/05/2019 8:34 pm
IMO, no matter how "super" a superbike is, it's just a bike, and if you try to make one bike do everything, it ends up as so compromised as to be effectively not actually very super at anything!
I'm lucky enough to be able to afford to buy/build just about any push bike i want, and i have 3 MTBs, a 180mm all the tricks enduro bike, a 150mm "messing around in the woods, but light enough to pedal on long days all-mountain bike, and a 120mm hardtail for when i want smooth and fast / light.
All are carbon frames, all run top line components (all XTR/XX1, all on the best forks you can get) and all are very different to each other, and not one of them does everything well enough to make me want to sell any of them........
Given that s/h bikes are really not worth that much money these days, i'd keep your current bike, with perhaps a few minor up specs to get a bit of mass out of it, and consider either spending the rest on a nice biking holiday to make the most of it, or perhaps buying a completely different type of bike for a change?
Posted : 15/05/2019 8:46 pm
Thanks for all the thoughts and ideas.
Like ?
I think after reading all the thread, i'm still likely to get a new bike for the 50th, but it's more likely to be a basis on a theme, which is a 130mm sale bike, so a T130 or whatever for 30% off on last years model (whatever that is). It may be a Specialized, it may be a Trek, but I'm thinking that an ex-demo/sale etc is going to give me best bang for my buck.
Posted : 16/05/2019 8:24 am
TBH, rather than get caught up in the boutique brand / super mtb thing of yeti/ SC/Ibis, hows about building the bike that you want, to do what you want ...
TBH it doesn’t mean stating with a super sexy US core brand. How about talking to BTR ...
Or another customer frame builder? It does mean you have to know what you want ...
Posted : 16/05/2019 8:43 am
Only real issue with any bike is the running costs...if you can afford the bike then great, but can you afford the running costs? The more expensive the bike, the more it'll cost when bits wear out, unless you 'downgrade' but if doing that, why spend the money on the fancier stuff to start with?
As long as initial costs and running costs are covered then absolutely knock yourself out and enjoy the new machine.
Posted : 16/05/2019 9:22 am
Only real issue with any bike is the running costs…if you can afford the bike then great, but can you afford the running costs? The more expensive the bike, the more it’ll cost when bits wear out, unless you ‘downgrade’ but if doing that, why spend the money on the fancier stuff to start with?
That's deffo a point to consider, looking at the higher build bikes yesterday then looking at CRC on prices and seeing £60+ for a chain, £100+ for a cassette, i'm really not feeling that at all. Currently on generic 10 speed stuff and can get the bits for 1/3 of that cost when i need to. Sure i get that i can't keep things cheap and have things super....
Posted : 16/05/2019 9:33 am
Given your posts on this thread @weeksy, i would be tempted to get a top spec T130. It will be what you are used to/like but just a bit better.
I really noticed a big difference going from RS to Fox suspension (though do note @Gotama's point above) and there is a slight difference between carbon/alu but i think its a very small difference and probably as much to do with the build as the material. I'm a bit torn on expensive drive trains, the pricey ones are nice but it costs a fortune if you clip your derailleur on something!
Posted : 16/05/2019 9:47 am
That’s deffo a point to consider, looking at the higher build bikes yesterday then looking at CRC on prices and seeing £60+ for a chain, £100+ for a cassette, i’m really not feeling that at all. Currently on generic 10 speed stuff and can get the bits for 1/3 of that cost when i need to. Sure i get that i can’t keep things cheap and have things super….
Is it though? People on here do tend to get their knickers in a right old twist over high end SRAM cassette costs, by just looking at the RRP & getting all a bit frothy.
But my experience (and that of others) is they last multiple times that of pretty much anything else, being basically all steel. My old XX1 cassette had done 5000+ km and would still take a new chain.
I'm kind of in the buy/ride what I want category, one of my bikes is pretty high on the niche scale, the other I guess is in the boutique category through the shop I race for, even at team discounts, an X01 Eagle cassette stings a bit up front, but it will literally last for years. I don't think i've ever bought anything other than a £20 12spd SRAM chain though - mostly because the solid pins last longer 🙂
Posted : 16/05/2019 9:59 am
 olaa
Like everybody else here is saying: you have got to demo a few bikes!
I have tried a few superbikes that i just didn't gel with, and ridden others that i loved. Just different feel to the bikes.
That said, when you have found a bike that you generally like the feel of: get top-notch suspension that works for you and spend money on someone that can tune it just right for you. Add a good set of wheels and controls that you like and you should be good!
For personal opinions on bikes that i like: I have had most of SC models over the last 8 years, and i have really liked most of them. The stand-out for me has been the 5010 though, not the fastest but so much fun! Certainly if you ride trail centres, that would be a fun and nimble bike.
That said, i have switched to a Geometron and for my riding i love it. It is set up with firm and fast suspension though making it very little like a gravity focused couch 🙂 Try one at PBW and see how you like it. Great support from Chris on set-up and tuning as well, that is worth a ton as well.
Posted : 16/05/2019 10:02 am
off the wall sugestion a bit but... every so often you muse abut a fast xc race bike. If I was going to buy something for a big birthday I'd want it too last beyond current fashion. How about getting a (custom or not) Ti 29er hardtail, a really nice light wheelset and as top end components as you fancy. You'll have a fast race bike, it will be different to what you have and you'll (probably) still be riding the frame in some guise in a decade.
I'd be temptd by di2, as IMO the one thing that really spoils a bike is when the shifting isnt perfect, and while I've not tried it, my understanding is di2 is fit and forget (except the battery!) shifting perfection.
Posted : 16/05/2019 10:17 am
100% my experience
Posted : 16/05/2019 10:21 am
 copa
This should have been posted on the general forum, it has nothing to do with bikes.
Posted : 16/05/2019 10:37 am
It's hard to get that wow feeling from the sort of jack all of all trades mountain bikes you're thinking of IMHO. I mean there's beautiful bikes to be found anywhere, but you're talking about something that's a lovely descender, climbs all right and it's reasonably light. It's a sort of functional package. The real jawdroppers that are exciting to just climb onto tend to be race bikes that are way more polarised - a crusher-of-souls XC missile, say, or a long travel enduro beast.
Posted : 16/05/2019 11:02 am
If you decided not to go fully mental on boutique you could look at one of the brands that’s still not hugely common but doesn’t go crazy on frame prices - Bird (I’m biased as I have one - but also have a Vitus and a Cannondale).
https://www.bird.bike/product/aeris-120-lt/?wccp_component_selection%5B1540817991%5D=225449&wccp_component_selection%5B1542283335%5D=233101&wccp_component_selection%5B1542289248%5D=234438&wccp_component_selection%5B1472646824%5D=4262&wccp_component_selection%5B1470824333%5D=224714&wccp_component_selection%5B1542381986%5D&wccp_component_selection%5B1470249895%5D=228064&wccp_component_selection%5B1470348967%5D=228303&wccp_component_selection%5B1541514648%5D=218230&wccp_component_selection%5B1542382563%5D&wccp_component_selection%5B1470347844%5D=220272&wccp_component_selection%5B1470257729%5D=2875&wccp_component_selection%5B1541532181%5D&wccp_component_selection%5B1542202456%5D&wccp_component_selection%5B1470505062%5D&wccp_component_selection%5B1470265806%5D&wccp_component_selection%5B1541527287%5D=234215&wccp_component_selection%5B1542383857%5D&wccp_component_selection%5B1470265807%5D=220228&wccp_component_selection%5B1470265808%5D=220238&wccp_component_selection%5B1470347847%5D=3029&wccp_component_selection%5B1470347848%5D=221494&wccp_component_selection%5B1542024798%5D=232181&wccp_component_selection%5B1542024799%5D=234989&wccp_component_selection%5B1542024877%5D=229998&wccp_component_selection%5B1542117017%5D=219702&wccp_component_quantity%5B1540817991%5D=1&wccp_component_quantity%5B1542283335%5D=1&wccp_component_quantity%5B1542289248%5D=1&wccp_component_quantity%5B1472646824%5D=1&wccp_component_quantity%5B1470824333%5D=1&wccp_component_quantity%5B1542381986%5D=1&wccp_component_quantity%5B1470249895%5D=1&wccp_component_quantity%5B1470348967%5D=1&wccp_component_quantity%5B1541514648%5D=1&wccp_component_quantity%5B1542382563%5D=1&wccp_component_quantity%5B1470347844%5D=1&wccp_component_quantity%5B1470257729%5D=1&wccp_component_quantity%5B1541532181%5D=1&wccp_component_quantity%5B1542202456%5D=1&wccp_component_quantity%5B1470505062%5D=1&wccp_component_quantity%5B1470265806%5D=1&wccp_component_quantity%5B1541527287%5D=1&wccp_component_quantity%5B1542383857%5D=1&wccp_component_quantity%5B1470265807%5D=1&wccp_component_quantity%5B1470265808%5D=1&wccp_component_quantity%5B1470347847%5D=1&wccp_component_quantity%5B1470347848%5D=1&wccp_component_quantity%5B1542024798%5D=1&wccp_component_quantity%5B1542024799%5D=1&wccp_component_quantity%5B1542024877%5D=1&wccp_component_quantity%5B1542117017%5D=1&wccp_variation_id%5B1470348967%5D=229669&wccp_attribute_colour%5B1470348967%5D=black&component_1541514648_bundle_quantity_349=1&component_1541514648_bundle_quantity_350=1&component_1541514648_bundle_quantity_793=1&component_1541514648_bundle_quantity_352=1&component_1541514648_bundle_quantity_541=1&component_1541514648_bundle_quantity_831=1&component_1470257729_bundle_quantity_209=1&component_1470257729_bundle_quantity_210=1&component_1542117017_bundle_selected_optional_364=yes&component_1542117017_bundle_quantity_364=1&quantity=1&update-composite=d8772fbb480ab73283ee7b80778d7da6#configuration
If this link works it could be a good option - X01 drivetrain, Pikes, Super deluxe shock, xm1501 Dt wheels which are decently lightweight, Maxxis tyres, Raceface bits, 150mm dropper, Guide ultimate brakes etc. Would be fun and poppy but is also very modern with the geometry (without being as long and slack as the Aeris 145) and great backup support with a lifetime transferable frame warranty. £4K but doesn’t really compromise on any kit at all. Just no carbon frame option.
Posted : 16/05/2019 11:16 am
