Thinking of changing from Alivio 3X9 to Xt 1x11 seeing as it's at a very affordable £180.
Will it be a straight swap or will I need a new rear hub.
Bikes a 2015 Giant Stance.
Posted : 09/03/2016 2:19 pm
same hub
Posted : 09/03/2016 2:26 pm
Same hub, just check that your cranks can be swapped to 1X, you may need shorter bolts.
Posted : 09/03/2016 2:32 pm
The cranks are FSA Comet not sure if they will work.
Posted : 09/03/2016 2:35 pm
Don't think they will as AFAIK they're a strange 3 bolt pcd
Posted : 09/03/2016 2:39 pm
my comets are 4 bolt, had the 1x on my singlespeed
Posted : 09/03/2016 2:52 pm
Yeah mine are 4 bolt like the deore on my (missus's) winter Hardtail. Just confused with the options for front ring a cassette options teeth wise. Need it to be OK on climbs.
Posted : 09/03/2016 4:03 pm
Bang a 30t ring on if you're worried about climbs and a 11-42 cassette
Posted : 09/03/2016 4:04 pm
