giant trance 27.5 o...
[Closed] giant trance 27.5 owners? good/bad what mods have you made to yours?
I'm getting a trance 2 in a couple off weeks,swapping the groupset for my xt,anything else want changing?
Posted : 31/03/2015 5:30 pm
Interested too. Got an SX , but with 2x10 XT instead of 1x11 Sram and Shimano SLX brakes on order .
Wheels might well be changed for Stans /hope too.
Posted : 31/03/2015 5:40 pm
Think Renton is best placed to answer this.
Posted : 31/03/2015 5:42 pm
1x10,hans damph + Magic Mary,converted to tubeless,renthal bars,xt brakes,Dropper post.
Really like this bike!
Posted : 31/03/2015 5:45 pm
Doctorgnashoidz !
Lol
Pretty sure most things will be fine, without too much procrastinating, just interested too, that's all !
Posted : 31/03/2015 5:51 pm
 Nick
Only added a dropper to mine, and that was after it was a year old.
I have a set of XT brakes on another bike and I did think about swapping them over, but the bottom of the range shimano jobbies are easily as good so haven't bothered.
Posted : 31/03/2015 6:06 pm
Are the standard wheels tubeless compatible?
Posted : 31/03/2015 6:08 pm
 Nick
I tried, with the supplied nobby nics, and failed. Went up ok with a compressor but came off the rim really easily for some reason.
Posted : 31/03/2015 6:12 pm
George cats....
Depending on your weight will determine if the rear shock needs tuning for you. Any thing over 80kgs will need it to stop the shock blowing its travel.
I had mine done by mojo and it feels loads better.
Stock saddle is a bit flat so I changed to my regular charge spoon.
I changed my forks, nothing wrong with the stock fox but I upgraded to a set of 150mm revelations to raise the front up a bit.
Standard bars etc are fine to be honest but it's a personal thing I guess. One thing that is good about the 2015Trance is that they have gone back to normal tapered forks rather than giants own overdrive system.
It's well documented on here that I've struggled to get used to the new geometry of this bike but I think I'm finally getting there. ......
[URL= http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0063_zpslmh0zwze.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0063_zpslmh0zwze.jp g"/> [/IMG][/URL]
I'm adding a giant dropper post to it later this week.
Not sure if the wheels are tubeless ready to be honest.
Posted : 31/03/2015 6:16 pm
 sv
I have a SX, changed the rear shock to a DB Inline (200x57) so slightly more rear travel. It's 1x10 with a Zee rear mech and NW chainring. Swapped the brakes over to a set of SLX ones I had and a Madison Flux saddle. Bars/grips changed to 750mm/thicker grips. Tyres are now Purg rear and Minion front both tubeless. Have a FIT cart to go into the fork too. Still to decide if it's a keeper...
Posted : 31/03/2015 6:40 pm
I have a 26inc wheel model, with Sram x5 gearing, 120mm epicon air forks, mavic cross rides, charge spoon on a joplin dropper (ks in post) 760 wide nukepfoof bars on a 50mm stem and deore brakes, bike is a small, only just put it together and ridden round Gisburn once and felt comfy. Anything anyone would change?
Posted : 31/03/2015 7:40 pm
I think the op is on about the new 27.5 version.
Never ridden an older one but heard good things.
Posted : 31/03/2015 8:15 pm
 LoCo
Heavy duty spacer & polymer eyelet bush in the top mount of the shock as they tend to wear fairly quickly, worked well with the team bikes from a few years ago with maestro systems.
Posted : 31/03/2015 8:35 pm
I have an older 26" Trance but the Maestro suspension platform is essentially unchanged - I'd agree with Renton about shock tuning if you're a porker like me - mine is in dire need of a tune - to prop it up when climbing it needs loads of air in, but it's then not soft enough to be working properly downhill. It's as if the ProPedal needs to be made more 'intrusive' at lower pressure. Will be off to TFT for a PUSH when I've got some spare cash.
Has anyone done this, out of interest?
Posted : 31/03/2015 8:36 pm
I believe giant dropped the lower linkage placement by around 9mm on the newer trance which apparently has made the rear end a lot more active and more susceptible to bobbing around.
Posted : 31/03/2015 8:38 pm
I built up an Advanced SX frame with an XO1 groupset, Pike 150s, Flow EXs on Pro2 Evos, Lev Integra dropper, XT brakes, SDG Belair 2 saddle and Easton Haven 740mm carbon bars. It's a great bike that goes up and down well and will be getting its first trip to the a Alps on Thursday to play in the snow with some Ice Spiker tyres. Can't wait!
Posted : 31/03/2015 8:48 pm
LoCo - Member
Latest Trance has bearings on the top shock mount (same with bottom mount). Rear end is very plush, I bought mine frame only, so came with a monarch RT3.
Very impressed with the bike, value for money on the full builds is good as well, frame is light, mine is at 29lbs with EXO tyres.
Posted : 31/03/2015 8:57 pm
Very nice that ^^^^and the one above.
Posted : 31/03/2015 8:58 pm
^^ very nice
Posted : 31/03/2015 9:07 pm
I've had a Trance 2 for about three months now and it is beginning to come into it's own as the suspension units bed in.
The things I have changed so far:
- Tyres changed to HR IIs straightaway.
- Handbars changed to Easton Havens purely because I had some lying around.
- Grips changed to Superstar as I prefer them.
- Seatpost changed to a dropper.
- Saddle changed out of personal preference.
TBH it's an excellent bike out-of-the-box but I would seriously budget in a new set of tyres. Everything else is down to pure preference.
The suspension units are pretty basic and, in the long-term, will probably be swapped out, but I'm in no hurry as they do the job.
Posted : 31/03/2015 9:20 pm
I got a trance 3 a few weeks ago ( 2014 ) couldn't get the standard plastic nobby nics to go up tubeless so I got some s.s.tactic wheels and purgatory front, ground control rear. This saved a ton of weight. Also converted to 1x10. Standard rock shox suspension is pretty good. Just under 30lb with dropper post. Anyone want to buy a nukeproof mega?
Posted : 31/03/2015 9:51 pm
If it rides like the 26" Trance it will be awesome!!
Posted : 31/03/2015 10:20 pm
Here's mine,
Built from frame only with
Pikes
Reverb stealth
Arch ex/hope
Easton carbon bar and stem
Tech 3 e4 brakes with 180 rotors
Full XX1 group set
Absolutely loving it. Weight is 28 lbs on Park scales at work!
[URL= http://i133.photobucket.com/albums/q64/peter_booker2003/image_zps83hjr0xq.jp g" target="_blank">http://i133.photobucket.com/albums/q64/peter_booker2003/image_zps83hjr0xq.jp g"/> [/IMG][/URL]
Posted : 31/03/2015 10:27 pm
I've been on a Trance I bought new and much upgraded since 2008. Maestro is superb. Which is one reason why I'm sticking with Giant and speccing it how I want.
Posted : 31/03/2015 10:44 pm
I've had my Trance 1 2014 for about 6 months and am really pleased with it
Only things I've changed are grips and seat to date. May go a little wider with bars at a later date but not really rushing
Most people seem really happy with them and they ride great so look forward to it and let us know how you get on!
Posted : 31/03/2015 10:47 pm
Question for a Trance 2014 owner - is the steerer a standard one or a Giant Overdrive one?
Thanks.
Si
Posted : 31/03/2015 10:55 pm
It says Overdrive on the head tube and overdrive 2 on one of the spacers on my 2014 Trance 1
Not sure if that helps? - it still rides great though and gave me an excuse to go out to garage and look at it again ๐Ÿ˜€
Posted : 31/03/2015 11:01 pm
1 and 2 (fox forks ) are overdrive 2, the 3 and 4 are normal.
Posted : 31/03/2015 11:16 pm
2014 models are overdrive2 which is the larger diameter steerer.
2015 models have gone back to normal taper.
Posted : 01/04/2015 8:02 am
Yep. 2015 models are Overdrive which is the normal tapered standard.
Posted : 01/04/2015 8:09 am
Mine's a 2014 Trance 2, so some of my points may not be valid/required.
Fox 32's were awful and got replaced with a set of 160mm Pikes and a 50mm stem (as I also get rid of OD2 in the process).
The rear fox ctd shock is simply rubbish (probably made worse by me not being the lightest).
The wheelset is lasting well, though you do need to keep a close eye on you spokes as they do seem to get loose quite easy.
Only had to remove play from the Hub's once so quite impressed there.
Brakes were 'ok', but I've replaced mine with SLX's and also changed the discs to 203mm in the front and 180mm on the rear.
Overall it's a really good bike/frame and some choice upgrades really enhance it.
Posted : 01/04/2015 8:24 am
They've improved the compression tuning on the 2015 Fox models I believe.
They're not the best but I wouldn't say they are awful, but then again I am only 70kg.
Posted : 01/04/2015 8:28 am
re the Overdrive stuff, I posted yesterday about this in relation to my 2015 Anthem SX. It has a normal tapered steerer on the Fox 32 CTD fork, a slightly oversized stem with a shim, and it says 'Overdrive' on the headtube. So normal fork, and a normal stem would fit in place of the shimmed Giant one.
Posted : 01/04/2015 10:08 am
Thanks to all of you that replied to my question re: OD.
Si
Posted : 01/04/2015 10:54 am
ignore
Posted : 01/04/2015 11:43 am
