Get my Joystick goi...
[Closed] Get my Joystick going again
Was working fine Saturday. I put it on charge last night and fell asleep, so it came off charge this morning.
All I can get now is, weak flash mode and very low output on the high setting ( the green LED shows indicating a full charge) there is no medium or low light now?
Posted : 13/01/2013 3:58 pm
is it damp and in need of drying out?
mine has failed when wet and worked again once dried on radiator
Posted : 13/01/2013 4:03 pm
No all fine. It was on flash mode for about four hours Saturday.
Posted : 13/01/2013 4:07 pm
In peoples opinion is that it?
It's a maxx, I've had it four years as a back up light but never had much use. Perhaps as an emergency get you home on a summers night..light.
Typical I find a use for it and it stops working.
So as I've never ever looked to see whats about, what would you recommend for an early morning road light.
Edit; I'd rather have something disposable than a £160 light again.
Posted : 14/01/2013 8:07 am
Send it back to USE.
Posted : 14/01/2013 8:11 am
 br
+1 USE
They are not particularly quick, but fixed my Toro foc earlier this year.
Posted : 14/01/2013 9:20 am
Didn't Trout do some Joystick upgrades to?
Posted : 14/01/2013 9:31 am
http://www.evomtb.co.uk/cateye-nano-shot-rc-front-bike-light-black
Chargeable by USB to which is handy if your in an office?
Posted : 14/01/2013 10:04 am
Batteries can 'die' after a while if not used/stored properly. Also, is the charger actually charging? Does it have a status LED on the charger that changes colour? If so, is it changing?
I've had a charger or 2 go after a few years use..
Posted : 14/01/2013 10:36 am
Plug the joystick into charge as per normal, then press and hold the power button until the light flashes rapidly and then try turning it on.
Posted : 14/01/2013 11:14 am
I think my front light came from Poundland. Build quality isn't the best, but it's still working as a 'look at me' light for gloomy morning and evening rides.
Posted : 14/01/2013 11:20 am
i sent mine back to use a year or so ago same sort of age as yours think they where going to charge around £80 to repair as out of warranty. leyzine light are worth a look usb chargable etc and i think about £45 for a front one same sort of power to.
Posted : 14/01/2013 11:39 am
