Genesis latitude 85...
[Closed] Genesis latitude 853 frame weight
Hello,
does anyone know approximately what the Genesis latitude 853 weighs? I am specifically after a 20.5 inch model...
Cheers!
Posted : 08/05/2012 12:47 pm
 ojom
Don't suppose you would want some DTSwiss XMM forks with that would you? Got a deal on at Genesis. 850 frame and fork package.
Not sure on weight sadly. Just started with Genesis last week.
Posted : 08/05/2012 12:57 pm
between 4 1/2 and 5 lb depening on size
Posted : 08/05/2012 12:58 pm
So same/similar weight to say an inbred,456 or piglet then?
Very interested in the fork deal, do get in touch!! Ta,
H
Posted : 08/05/2012 1:12 pm
 ojom
Got an email i can use to take this off here?
MD
Posted : 08/05/2012 1:43 pm
Harryfox (at gmail)
Posted : 08/05/2012 1:52 pm
 mboy
Nooooo, about a lb lighter than those. A medium sized 456 is over 5 1/2 lb, my old 853 framed Altitude (the Latitude will be a tiny bit heavier with its 44mm headtube and seatstay plate) was just on 4 1/2 lb including bolts and seatclamp in a medium. A 20.5 Latitude would at a guess be just shy of 5lb, the others you mention in the same size, more like 6lb.
Just for reference, now got a Ti Altitude instead of the 853, just over 3.4lb it was including bolts but no seatclamp (about 25g extra)! ๐Ÿ™‚
I think the Latitude was described as being the same weight as the Altitude if not a tiny bit lighter. Although the 44mm headtube and stay plate are heavier, the tubing profile has been custom reworked to remove the need for the head tube gusset/brace thingamy.
I've got a 19 inch latitude, don't know what it weighs but it's one of the lighter ones out there.
Great bike BTW.
Posted : 08/05/2012 2:37 pm
Paul is correct. By using a larger headtube you have more weld area and don't need a strengthening gusset. Also the seatstays were changed between Altitude and Latitude frames which kept the weight down.
Posted : 08/05/2012 2:49 pm
Ti one on ebay still I think it's an xl I think. Head tube is best to positive id size..
Posted : 08/05/2012 2:52 pm
