Garmin USB not reco...
[Closed] Garmin USB not recognised. ๐Ÿ™
I just went to upload todays big road ride and I got "USB not recognised" , tried changing the USB cable but to no avail. Any Ideas ? , Im thinking of giving the usb port a blast with contact spray to see if It is maybe just dirty.
Your advice is appreciated.
Posted : 08/05/2014 9:27 pm
Also worth switching your PC off and on again (seriously). USB ports often get into a corrupted state after Sleep mode has been used (and/or devices have been removed with being "Ejected").
Posted : 08/05/2014 9:30 pm
I think there is a glitch on the site, as it wouldn't recognise I've ridden yesterday and today when I tried to upload earlier. There was an 'error n page' message in the bottom left corner and it wouldn't load properly
Posted : 08/05/2014 9:32 pm
Garmin? Wet ride? I've had this a few times, Garmin dries out over a few days and then works fine.
Posted : 08/05/2014 9:35 pm
Get this occasionally with my 200, usually swapping ports, switching off/on etc works eventually.
Posted : 08/05/2014 9:44 pm
my 810 often does this too on strava, I swap usb ports around/log out,back in to strava and it works fine.
Posted : 08/05/2014 9:57 pm
Cool , I'll give It a try . failing that I'll try some contact spray at work tomorrow.
Posted : 08/05/2014 10:08 pm
Are you using garmin express? I lost all contact with my garmin ANT today. Exoress needed upgrading and once done all was fine.
Posted : 08/05/2014 10:14 pm
Cleaned the contacts with white spirit and dried with the hair dryer. All good now . ๐Ÿ˜€
Posted : 08/05/2014 10:17 pm
