Garmin 800 uploadin...
[Closed] Garmin 800 uploading route problems
Had mine for a while and its always worked fine
The other week it turned off mid ride while following a course i got from the Garmin Connect site, it then re started and got me to the end of the course
Now when i plan a route on bikehike like i have done loads of times before without any probs...i hit the button to sent it to the Garmin and it never shows up in the course section on the 800
I have found the files in the NewFiles folder on the unit but thats as far as they get
any ideas ??
Andy
Posted : 31/08/2011 12:39 am
I've had that problem too? I'm not sure if it will only show a limited number of courses (4 or 5) as I deleted some superfluous routes from the 800 folder and the one's I wanted then appeared โ—
Posted : 31/08/2011 1:45 pm
cheers,, will give that a try but i am sure in the past i have had lots more routes saved on the 800
i see on the garmin forums people talking about corrupted files , but all that sort of stuff is a bit too tech for me
Posted : 31/08/2011 10:19 pm
I have the 705 rather than the 800 but have encountered similar problems when using the memory map software.
I would suggest downloading the file off whatever site you like then sending it to your garmin using Garmin Training centre.
Sometimes you have to convert the file from a gpx to tcx to do this.
There are lots of free programs to do this.
Here's one.
[url= http://www.teambikeolympo.it/TCXConverter/TeamBikeOlympo_-_TCX_Converter/TCX_Converter.html ]TCX converter[/url]
Posted : 31/08/2011 10:23 pm
cheers thanks for that,
I have used www.bikehike loads of times without any probs at all,,just a bit strange its just started doing this
i am waiting on a reply from the garmin help people,
Posted : 31/08/2011 10:29 pm
i can load up from the garmin connect and garmin basecamp fine
but not any of the sites like bike hike or any other route file i find online
the guy on the garmin help desc says its nothing wrong with the 800 it has to be a problem with the files i am trying to load up from the non garmin websites
think i may try a full reset to see if that helps me out
Posted : 02/09/2011 10:46 am
