Full Face Helmets a...
[Closed] Full Face Helmets and weights ?
Hi, i have narrowed my helmet search to 2 helmets but cant find the weight of the, hope you can help.
Fox Racing Rampage Size-Small
Giro Remedy Size-Small
Thanks
Posted : 06/12/2011 11:14 pm
 5AM
They both come in about 1100 grams if I remember rightly.
I have them both, and to be honest the fit is fairly similar on each. Don't think you can go wrong with either.
Posted : 07/12/2011 2:21 am
really , i agree with you !
Posted : 07/12/2011 4:02 am
Before you do decide have a look at the Oneal Airtech, loads better helmat with new technology as oppose to a 10 year old mould
[img] http://t3.gstatic.com/images?q=tbn:ANd9GcSihVDVxho0_Gr-uOHV5XyW-hqwU22n2J2EvyGv5aZQXVYBmHcG_k6MetY8 [/img]
£110 and comes with the best locking device ever, no messing with d loops! Weighs in at under 1100g too
The two you mention are the same mould as the one Oneal sell for a RRP of £59.99
Posted : 07/12/2011 7:25 am
the two mentioned are completely different to each other so not sure where you're getting that from ❓
To the OP, both good helmets but if you care about looks at all get the Fox as the Giro's a bit fugly
Posted : 07/12/2011 8:04 am
Wouldnt worry about weight, IMO it's not an issue as the weighs arround your head rather than on it, and venting isnt the end of the world, I've a mid priced 661 so neither the lightest or most vented but it coped with XC rides in Spain. Just cut out the fabric liner arround the vents to encourage more airflow made ahuge difference.
Posted : 07/12/2011 10:41 am
 ianv
If you are worried about weight. My mate has a Kali and it is VERY light.
Posted : 07/12/2011 11:30 am
As above a 500g piss pot is lot less comfortable than a 1kg FF.
If your riding requires a FF the weight (within reason) is not that important.
Posted : 07/12/2011 11:41 am
Considered one of these?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=58788 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=58788[/url]
Very light and unobtrusive to wear. They have less lairy ones for £99 too.
Posted : 07/12/2011 12:06 pm
 jedi
i use kali avatar is stooopid light (lighter than a troy le carbon) and £200 🙂
Posted : 07/12/2011 12:28 pm
