Front mudguard opti...
[Closed] Front mudguard options...
..which works well without interfering / being a faff? (On suspension forks.)
I have a couple of the zip tie on arch plastic things - but have had some faff with tyre rub - anything else to consider?
Posted : 31/07/2017 12:08 pm
I use the MuckyNutz mudguard that goes on the downtube. Simple velcro attachment loops.
Posted : 31/07/2017 12:10 pm
Powa Dfender is the least faff to attach
IMHO the little bendy mudguards dont really do a lot. If its mucky/wet I will run a rockguardz pg450/pg350 keeps the much out of your eyes/face most of the time.
Posted : 31/07/2017 12:11 pm
mudhugger FR.
Posted : 31/07/2017 12:12 pm
Mudhugger FR or the new adjustable one
Posted : 31/07/2017 12:19 pm
Mudhugger FR is the boy.
Posted : 31/07/2017 12:25 pm
is the coverage better or worse on the new flatpack one?
Posted : 31/07/2017 12:26 pm
They're all a faff if you like to lay your bike down in the car.
Posted : 31/07/2017 12:48 pm
What!?
Lay bike down, mudguard *might* slip round a bit. Take bike out of car and push back. Sod all faff, it takes longer to straighten the antimacassar on your seat headrest. ๐Ÿ™„
Posted : 31/07/2017 12:55 pm
jam bo - Member
FR is better but the flexible one fits larger tyres (or forks with less clearance) better
Posted : 31/07/2017 1:27 pm
What!?
Well, I like my mudhugger FR but if I leave the bike in the car overnight in a position that distorts the guard it stays in that shape until I get a heatgun on it. I just have to be careful
Posted : 31/07/2017 2:36 pm
Just use 4 of these velcro ties instead of zip ties and you can take the guard off when you need to.
Posted : 31/07/2017 8:09 pm
Anyone else have to look up antimacassar?!
Posted : 31/07/2017 8:21 pm
Me, I got this by way of an explanation.
Posted : 31/07/2017 10:03 pm
This works well (after adding a washer made from old inner tube to stop it coming loose)
https://www.leisurelakesbikes.com/10510/products/cube-race-26-28-inch-mtb-mudguard-black.aspx
Posted : 31/07/2017 10:20 pm
SKS Shockboard. It looks a bit Moto, but it works.
It slides on to the bung you leave fixed in the steerer. Spare bungs are available, so you can swap the guard between bikes.
Posted : 01/08/2017 2:54 am
I tried the sheet plastic type guards and found problems in the car and sometimes with tyre rub too. I've gone back to a bit of inner tube from the fork crown to brace. A crud catcher would help with this but it cuts out a lot of the muck.
Posted : 01/08/2017 6:24 am
The Defender works so much better than anything else I've tried including the mudhugger, rockguardz and about five different brands of the flat plastic type. Dead easy to take of and put back on too.
Posted : 01/08/2017 6:34 am
shifter - Member
Which is why the MuckyNutz trumps the lot as it flexes straight back to shape whereas the MH/Powa/Zefal offerings do not I believe.
Posted : 01/08/2017 7:52 am
I have the SKS shokboard on my rigid SS, although currently unclipped for the summer. It's a surprisingly good mudguard, I use the bike for riding in the gloop and it makes a huge difference in how much I get covered in crap
Posted : 01/08/2017 9:30 am
I would dispute this. The FR I have has not had an issue at all resuming its shape if it has been bent either in car transport accidentally, or as a result of a genuine crash. A non issue imo.
Posted : 01/08/2017 10:59 am
SKS Shockboard
I've broken load of these.
We've mangled and creased several of these
velcro ties
Winner! I took a wee drill to my Rockguardz (will also work for Mudhugger I'd expect) to turn the zip tie holes in to slots and used the double-sided velcro from a dead Mucky Nutz. 30 seconds to take on and off as required.
Posted : 01/08/2017 12:40 pm
Cheers all - velcro ties I have hundreds of at work...and will try a MuckyNutz
Posted : 01/08/2017 1:12 pm
