Front mech set up f...
[Closed] Front mech set up for double ring
Where should I position the lower part of the outer plate for a 22-32 set up?
I have attached it at the moment in the correct position if there was a big ring but it looks rubbish!
Any pointers?
Posted : 24/04/2009 9:59 am
set it up the same way you would do for the big ring but in relation to the 32 ring
Posted : 24/04/2009 10:14 am
thanks.
Posted : 24/04/2009 10:21 am
i think. come to think of it i have an actual slx special 2 ring shifter thing so it might not be the same when you have a normal one. who knows.
Posted : 24/04/2009 10:26 am
If you have a 4bar or rocker link full suspension don’t move the front meck down to far or it will hit your chain stays as the rear compresses.
It is a hardtail (PA) that I'm de-singlespeeding for a bit. They're an XT shifter, mech and chainset. I'll drop it down some more and see!
Posted : 24/04/2009 10:35 am
