Front disc vibratio...
[Closed] Front disc vibrations?
4 Users
My front brake is squealing when braking. Nothing unusual there until I came to clean it with a paper towel and brake cleaner.
It was like running your finger round the rim of a brandy glass, the disc vibrating as I run the towel round it. It sounds exactly like this when I'm braking.
Is this normal? Never noticed it on any other disks,disc is a SRAM 200mm centerline.
Bike is pretty new with only a couple of rides on it and the front brake has always squealed.
I've tried roughing up the disk with sandpaper but it still plays a tune when I wipe it with cleaner.
How do I stop this?
Posted : 22/12/2018 5:02 pm
? bit of inner tube clamped between rotor & hub ?
Posted : 22/12/2018 5:42 pm
Have you worn in the pads to the disc? You need to do multiple runs getting up to say 20mph on the road and then braking really hard to a stop with both brakes. I usually try to do this about 10 times when I have new pads / discs. Always seemed to work. Got centreline discs on both bikes - 200/180 on one and 200/160 on the other.
Posted : 22/12/2018 7:45 pm
Is the calliper spacer correct for the disc size?
Posted : 22/12/2018 8:10 pm
I've tried bedding them in but can't seem to stop the vibrations. Worth trying to clean everything up and give the pad a rub with sand paper and try again?
Posted : 22/12/2018 9:17 pm
Yeah and and dishwasher them for good measure.
Posted : 22/12/2018 9:56 pm
