Frame, forks and so...
[Closed] Frame, forks and some other bits and bobs (price drop)
Getting rid of stuff I just don’t need any more.
21” Rockhopper frame. A few marks as you would expect from a used frame (see photo’s). Seat clamp and headset included. £100 posted.
Rockshox Dart 3 100mm QR forks. Really good condition with a small rub mark on the righthand graphics/paint. Steerer is 217mm long with SNF fitted. £60 posted
1 x Shimano SM-RT61 160mm 6-bolt rotor. Great condition and true. £10 posted.
Fox Float R “itch switch” rear shock. (As fitted to Spech Enduro’s from mid ‘0’s). Recent air-can service so no leaks and no marks whatsoever on the shaft. 190mm I2I. £40 posted.
Old coil shock from Marin frame. Separate compression and rebound adjustments. Could do with a service. 170mm I2I. £15 posted.
2 x Shimano 6-bolt to centre-lock adapters. Fitted and removed once. £10 each or £18 the pair posted.
Paypal gift to.... andy dot dobson63 at googlemail dot com
Think that’s all for now but may add stuff as I find it lurking ?
Andy.
Posted : 18/03/2011 7:51 am
