Hi,I'm thinking about buying one of these,it says on the Fox site, that the travel is adjustable 140-150-160mm and I'd need to reduce it to 140,my Google fu must be weak as I can't find a clear description of how to do it online,the fork manual just says it can be done.Is it a matter of inserting spacers?I'd appreciate some advice.
Posted : 08/11/2019 10:47 am
Based on my 2015/16 36.... you want to check you can actually buy the spacers... if you can you (based on 36) move a bolt and add the spacer assuming you can buy one.
Posted : 08/11/2019 10:52 am
