Fox X2 Recall
[Closed] Fox X2 Recall
47 Users
I don't use spacers in mine. Run it at 190 psi on a YT Capra and weigh (if I'm lucky and in the bathroom) 86kg.
I cant read the German email from YT, so will carry on till Mojo have some replacements.
Posted : 17/10/2016 3:24 pm
190psi in mine, with 5 spacers, according to the manual, max is 5 and 300 psi....
hopefully more info will be forthcoming soon about what to do about it, but until then I am not going to put the float x that the bike came with back on, and will continue to ride it, as I have for the last 6mths.
Posted : 17/10/2016 4:07 pm
I run 1 spacer as my frame is very progressive. I'm sure it will be fine and no one will die, just a bit off on their part. If the company I work for told our customers they were to stop using any boats our material went into, and stop building any yachts they were building and then just went quiet we'd probably never sell anything ever again and have millions to pay in damages. Just a bit annoying is all
Posted : 17/10/2016 4:11 pm
Yeah, incredibly poor from Fox. I don't think they even have this on their own website, just a bunch of press releases to media.
Posted : 17/10/2016 4:35 pm
Is there anyone that doesn't use spacers? If everyone needs a smaller volume, what is the point of the large air can?
I blame the marketing/press for large volume air cans coming on everything. When RS released the Debonair can for the Monarch shock it was perceived as "better" or an "upgrade" over a standard air can. So next year any bikes sold without Debonair were deemed not as good as those with the Debonair. I think this forced many companies to go large volume for the look, and then fit spacers again to get the right progression tune from the shock.
I think some people need to calm down a little as well. Of course Fox have had to tell people to stop riding as soon as they were aware of the issue. Lets say they waited to announce this only when they had a solution in place but you're unable to ride because you have half an air can stuck in your thigh. You'd instantly be asking how long they'd known about the problem for.
In the grand scheme of things you've missed one weekend of riding so far. If you have to miss another, maybe deep clean the bike, service your forks or something. I'm sure Fox will have a fix for this as soon as possible.
Posted : 17/10/2016 8:03 pm
Big air cans are good because you can always add spacers, if it's too small there's not much you can do.
It hasn't cost me any riding at all, some communication would be nice though.
Posted : 17/10/2016 9:24 pm
I'll just leave these here.... 😉
Posted : 18/10/2016 2:44 pm
That's to do with the volume of the negative spring rather than overall volume though. The large volume negative spring was designed to improve suppleness/sensitivity of the initial stroke, Fox followed suit and it seems didn't take into account the higher pressures required.
Being able to custom tune volume is a good idea, with no downsides, what's not to like?
This
Posted : 18/10/2016 3:08 pm
"if it's too small there's not much you can do."
Except buy an optional larger air can. Which is what used to happen. Now most of us ride oversized air cans reduced with spacers adding weight and bulk. With nearly everyone running air shocks it's not as if the bike manufacturers couldn't match their linkage curves to them.
Posted : 18/10/2016 4:41 pm
Ideally make both options available, you can buy a CCDB with normal or big air can. Butif you can only have one it'd have to be the big one
Nothing to do with the fact my frame needs a large air can... 😆
Posted : 18/10/2016 5:04 pm
Anyone heard anymore on the recall, my shock is affected and no news for over a week.
Posted : 23/10/2016 3:14 pm
Just returned from a week of riding in Molini, X2 is still in one piece and hasn't grenaded itself.
Will keep riding the bike until Mojo contact me, they know I have bought a shock from them.
Will be interesting to hear how they handle the people who are using more than 250psi to achieve the correct sag, when the shock was originally sold with a 350psi max pressure and has subsequently been reduced post sale. Replacing the Float X2 with a coil X2 would be the only solution I would accept!
Posted : 24/10/2016 10:22 am
It would seem the max pressure was 350 at some point ([url= http://www.ridefox.com/help.php?m=bike&id=556 ]this page[/url] still mentions "80-350psi", then goes on to say "MAX 250!!" further down)
[url= http://www.ridefox.com/2016/dl/bike/605-00-141-FLOAT%20X2%20Tuning%20Guide-JD.pdf ]An older manual[/url] says 300psi, and the [url= http://www.ridefox.com/2016/dl/bike/605-00-141-FLOATX2-Tuning-Guide-revC.pdf ]current one[/url] says 250.
Posted : 24/10/2016 10:34 am
So my Mojo custom set-up (with climb switch) has 5 spacers and is running 185 psi. No sign of deformation and it's working fine. Jumps and lands ok; takes trail features in its stride.
I'll trust what chris has done over a generic US safety / litigation announcement that after 2 weeks still hasn't got any advice around it
Stupid fat americans (allegedly)
Posted : 24/10/2016 10:42 am
Sir HC - Member
Not convinced that would work in a lot of cases. really hiugh pressures would need a really high rate (read heavy) spring and a coil probably can't give the kind of ramp up that an air spring with lots of spacers can.
This is two weeks since they announced the fault and as far as I can tell there has been no further communication. That's appalling. That's me not buying a Transfer post then
Posted : 25/10/2016 7:55 am
Until the plan of action is agreed in the US by the CPSC, it is illegal for them to make any further announcements.
They have to follow a legal process when doing a voluntary recall, part of that is no further communication until the above is sorted.
American law, basically.
Posted : 25/10/2016 8:43 am
The unofficial version I heard from someone in a shop with one was along the lines of somebody put way too many tokens and 300psi into one.. after the conversation he happily raced on it.
Posted : 25/10/2016 8:58 am
mikewsmith - Member
Like I said earlier, dick'eds tinkering with stuff that takes years to master....i struggle to sympathise, other than setting my sag I send my suspension off to TF for anything more in depth.
Posted : 25/10/2016 10:01 am
Shocks without safety features built in:
- you shouldn't be able to overload with tokens - it certainly makes no sense for them to supply more than the max that can be fitted with the shock as happened with mine.
- it's not particularly clear when the air can is fully closed and a surprisingly small turn between open and closed.
You'd have thought this would have shown up in testing - overfill with tokens, overpressurise, stick it on a dyno.
Posted : 25/10/2016 10:18 am
Any tester worth their salt would have done that. Any good tester would have tried putting in more than the max that can fit too, and also tried to out in things that customers might do themselves, because people are morons.
Posted : 25/10/2016 6:29 pm
and sometimes you can repeat a test 100-1000 times and not get the outcome. It could have been a tiny manufacturing defect on the failed part etc. that combined with extreme uses lead to failure. Unless you have a foolproof method to find every potential fault in a product you should probably leave off slagging them off for a single failure.
Posted : 25/10/2016 11:23 pm
mikewsmith - Member
I don't think Fox think it was a tiny manufacturing defect; they're certainly acting like they've investigated the failure and discovered they've ****ed it.
Posted : 25/10/2016 11:35 pm
If fox are gagged by US law until a solution is reached that information should have been included in the original press release or circulated in the UK by other means. Can't really argue with them pulling the shocks and then a solution taking a while but zero communication is fairly unforgivable. I see ohlins have a rear air shock available......
Posted : 26/10/2016 7:37 pm
Exactly, stuff fails that's fine. But communicate FFS, and if it is a law thing saying they can't then communicate through CPSC.
I'm sure they'll be fine, but it's a bit of a pricey item to 'probably be fine'
Posted : 26/10/2016 9:23 pm
Rode my X2 at BPW today, where it exploded and removed both my legs.
Nah, not really, it were ace! 😆
[img] :large[/img]
Posted : 28/10/2016 8:27 pm
Here's some info on the changes.
Posted : 01/11/2016 7:55 am
So looking at the changes I feel happy to continue to use mine.
Based on the fact its got no tokens in it and is no where near 300psi.
If the upgrade is free I will do a swop when they have some in though.
Posted : 01/11/2016 8:51 am
Ok so a bit more info that picture on the Instagram account is with a new shock for 2017 but the new parts will be from mojo. And retro fit to the earlier affected shocks in still going to carry on riding mine as it is.
Posted : 01/11/2016 3:13 pm
Mojo have news, check out their site for it.
You will need you serial no. to hand.
Posted : 01/11/2016 4:33 pm
Wow the original can thickness was stupidly thin, a basic calc puts the new wall thickness more in the right ball park for the kind of pressures expected.
Posted : 01/11/2016 5:13 pm
I'm sure this a USA legal type thing (technical term 😀 ) but they're calling it a voluntary recall?
Posted : 01/11/2016 5:18 pm
Voluntary on their part. As opposed to not recalling but dealing with the legal ramifications, etc intead
Fox site dumps you out a reference number to take to your local bike shop
Posted : 01/11/2016 5:31 pm
Anyone tried this yet? I bought a 2nd hand X2 for my new build about a week before the announcement and I'm not sure where I stand. I've just emailed Mojo with the Fox code so we'll see soon enough but wonder if anyone's had that conversation yet?
Gaz
Posted : 02/11/2016 9:26 pm
You can now send your shock back to mojo direct or through your local bicycle shop turn around initially at 1-2 days use the supplied reference number generated off the web
Posted : 02/11/2016 10:48 pm
I'm lucky enough to live quite near Mojo, so popped over and they fitted the parts whilst I waited. 15 mins total waiting time! Nothing really. Gave them the ref number before hand which I think smoothed proceedings.
It's back on the bike now, happy days.
Speeder, use this link:
http://www.ridefox.com/2016/content.php?c=floatx2recall
/p>
Enter your details and the shock serial there, and it will tell you whether it is faulty or not. Then quote the ref code it gives you in orange when you drop it off/send it to Mojo.
Posted : 04/11/2016 12:54 pm
Mine's gone back today in the post.
Posted : 15/11/2016 3:13 pm
I just received mine back after its recall,been stripped down,new seals fitted and Air can fitted,quite happy about the seals an service for free
Posted : 15/11/2016 3:31 pm
How long was the turnaround.
Posted : 15/11/2016 4:09 pm
sent mine Monday and got it today,not sure if it was because i asked them to have a look over it as it felt squishy that it took longer,it was in their shop since Wednesday
Posted : 15/11/2016 4:11 pm
Got mine back and refitted, was a few days delay as Mojo ran out of repair kits but no big issue, expect they're back to a coupel days turnaround now.
Must say though, whatever your thoughts on how Fox have dealt with this, Mojo for me have been a joy to deal with, just very professional & polite, phone calls returned every time, updates when shock was ready and being shipped, sorted me out for postage from Ireland, the lot.
Great service, especially considering the amount of these they probably had to deal with. Will definitely be buying from/servicing with them in the future.
Posted : 02/12/2016 11:01 am
Must get round to getting mine "fixed" i guess. (i've been having too much fun just riding it tbh 😉
Posted : 02/12/2016 11:11 am
I didn't actually get round to getting mine fixed - as I was well under the pressure & spacer limit anyway.
Then I went & sold the bike. Oh well!
Posted : 02/12/2016 11:15 am
Hob Nob - Member
I presume you informed the buyer of the safety recall?
Posted : 02/12/2016 1:14 pm
Dropped mine off at the LBS to go back to today.
Are they servicing all that come back from recall? Do they include a note of what work has been carried out when they return them?
Posted : 03/12/2016 1:58 pm
No servicing, just air can replacement.
Posted : 03/12/2016 5:46 pm
You presume wrong.
Posted : 03/12/2016 8:34 pm
So he already knew, right?
Posted : 03/12/2016 8:46 pm
Of course!
Posted : 03/12/2016 8:57 pm
Not a service exactly but I think the outer seal is replaced along with the can and there'd have to be a quick relube inside. Damping side of things wouldn't be serviced in any way.
Posted : 04/12/2016 10:14 am
Mine had a set of seals and service noted down on the job sheet,
Posted : 04/12/2016 6:42 pm
Page 2 / 2
