Fox X2 on 130mm tra...
[Closed] Fox X2 on 130mm trail bike. Any takers?
Seriously considering an X2 on my 5010cc V2.
Anyone else running this much shock on relatively short travel trail bikes? Reckon it may be overkill or just adjustability nirvana?
Posted : 10/05/2017 4:45 pm
Coil or Air?
Posted : 10/05/2017 4:56 pm
Definately air.
Posted : 10/05/2017 4:57 pm
I've just dropped a coil X2 on my 120mm T1-29 trail bike.
Posted : 10/05/2017 4:59 pm
What does it ride like? is it easy enough to get set up?
Posted : 10/05/2017 5:03 pm
If it fits I think it will improve the performance no end. I think the main reasons you don't see them fitted often are weight and that you're probably not doing as many long sustained downhills where the reservoir helps with over heating.
Posted : 10/05/2017 5:04 pm
Its gonna take some fettling (huge adjustment range), but in initial tests it feels awesome and exactly like you'd expect - It might be a *shade (lots) overkill!
For context I also dropped a coil onto a Trek DRCV Fuel EX a few years ago and that turned it into a trail monster. More grip, more support from the spring everywhere and no mushy feeling.
Posted : 10/05/2017 5:08 pm
 SamB
I stuck a Float X2 on my Carbine (140mm). Got it from TFT so didn't have to think about tuning it particularly. Rides fantastically if you ride in a more "aggro" manner than a Float DPS or RP23 is set up to handle.
Probably overkill, but then I run Float 36s with a 20mm axle on my hardtail and think that's perfectly warranted 😈
Posted : 10/05/2017 5:25 pm
Was considering one for my Hightower and have seen TF tuned have the 2018 one available for pre order for the princely sum of £699 😯
Posted : 10/05/2017 5:38 pm
I've got a float x on my bike and it's brilliant, especially after a tune
Posted : 10/05/2017 5:46 pm
I've had a ohlins stx 22 fitted to my 5010 cc and it's made a good bike great.
Posted : 10/05/2017 6:44 pm
I've had a DBair (not Inline!) on my 140mm Spitfire from new and I'd only consider shocks like the X2 as an alternative.
Not just adjustability nirvana but damping control nirvana too!
Posted : 10/05/2017 6:50 pm
Cheers for the answers folks!
Like the sound of the Ohlins STX 22 pyekid, is the bike still poppy and playful with the new shock?
Posted : 10/05/2017 7:30 pm
Fitted a DHX2 onto my Riegn - everyone says that coils are less lively.
Complete balls IMO, it's way livelier and poppier than my Monarch ever was - mostly because you can tune the high speed rebound to your taste - but also because you don't have to run tonnes of compression to control the midstroke.
Posted : 10/05/2017 7:36 pm
Bike is just better allround. Still playful and haven't felt the need to mess with it since Jake at sprung suspension set it up 5 months ago.
Posted : 10/05/2017 9:58 pm
 poah
zelak999 - Member
Definately air.
id go coil over air
Posted : 10/05/2017 10:32 pm
I've just dropped a coil...
S****
Posted : 11/05/2017 8:36 am
id go coil over air
I guess i'm a litle bit weight conscious too.
Any idea of the weight of an air X2 200 x 50?
Posted : 11/05/2017 8:41 am
Circa 500g from memory, to be honest though, the performance you gain from the weight sacrifice over a monarch/float evol is a no brainer!
Currently mulling over a new bike built (to replace both Reign and Smuggler) and an Fox 36/Float X2 Trek Fuel EX would be pretty mega for the stuff I ride.
Shame that the Float X2 doesn't come in a 210x52.5
Posted : 11/05/2017 9:09 am
 poah
CCDB coil IL won't be much more with a valt spring than the X2, certainly nothing you'll notice.
Posted : 11/05/2017 9:17 am
Rumour has it that the X2 for 2018 comes in metric sizes - dunno if that helps or is just a poisson rouge
The obvious answer would be Cane Creek's new version of the Inline, but it looks like the durability is already coming into question again.
No reason not to put an X2 on a 130mm bike IMO, Orange are speccing them on their new 135mm 29er.
Posted : 11/05/2017 9:22 am
Fox don't list a 210x55, with rockshox you can turn a 210x55 into a 210x52.5 with internal travel adjusters. Will call Mojo at some point as they should know what is possible.
Posted : 11/05/2017 9:41 am
I'll save you the effort, they can't make one in those dimensions, due to the way the X2 works, they can't limit the stroke length on a longer stroke shock (apparently).
I'm seriously toying with the idea of putting an X2 coil on my Fuel, the bike is ridiculous & have a feeling it would be pretty awesome with the coil on with shorter travel.
The other option with the Fuel is a 55mm stroke shock does fit & doesn't cause any clearance issues - makes it ~138mm travel on the back from memory.
Posted : 11/05/2017 9:55 am
They should be able to as thats how Fox used to make a 200x51 X2. Its a 200x57 with a 6mm internal limiter to limit the stroke.
They cannot reduce the eye to eye on one but as long as the eye to eye length is the same then they can make a X2 to suit the stroke.
Posted : 11/05/2017 10:29 am
Apparently something to do with the new air can design - still good to know if they potentially can - would also need to check if there is clearance for the shock body.
Posted : 11/05/2017 11:09 am
It's made the bike much more surefooted and I've not lost anything I'd say.
My DPS broke and I always had to run it at near max pressure so it didn't wallow.
Posted : 11/05/2017 12:44 pm
Just thinking the same about my 5010, the float I have just doesn't quite live up to the rest of the bike when shit gets real.
Jacksprogis - that looks tidy, what travel are your 36s at? Just fitted 150 pikes to mine over 140 BOS and it has improved it no end...looking at yours maybe I could have got away with more!
Posted : 11/05/2017 12:55 pm
150 mate. Feels bang on, might go 140 on my new one though.
Posted : 11/05/2017 12:58 pm
I have one on my 135 mm travel Hightower. It's good.
Don't worry about the set-up. Start with the Fox recommended setup for your weight (tend to be pretty close), and then using the Cane Creek "Dialed" app. On the app you will have to blag your way through setting up a Cane Creek Double Barrel, but after that it's really useful via the "Tweak" settings part. You select what you want in English (eg. too firm / more pop / feels dead / harsh / chattery) and it will tell you what to alter (HSC, HSR, LSC, LSR). Or borrow/hire a Shockwiz!
Posted : 11/05/2017 1:04 pm
Awesome, I'm sold. Just need to wait for Mojo to get the 2018 stock in now.
@jacksprogis that looks sweet, tempted with the 150 36's too.
Posted : 11/05/2017 2:16 pm
Server outage at work so had some spare time to call Mojo. No word on when metric shocks will be available and they didn't let on to whether they are adjustable.
Would guess the coil is fairly straightforward.
Posted : 12/05/2017 11:37 am
 kevt
For those with a solo 5010, I have recently had the fox ctd pushed and I think it improves the performance a lot, worth considering at slightly lower cost.
Posted : 12/05/2017 12:09 pm
Does anyone fine there is a noticeable rattle from the rear end, over rough ground?
Everything is tight, torqued etc - fairly certain it is the mech but was fine on previous bike
Posted : 15/05/2017 11:50 am
same here, rattling, in general cant really tell where mines is coming from, but its rattling on anything climbing off road pretty much, if its got bumps/roots/rock I can hear it rattling somewhere
but stationary compressing the suspension I cant get it to make the noise at all
Posted : 15/05/2017 11:55 am
https://www.ridefox.com/help.php?m=bike&id=757
52.5mm listed on the IFP height table. Can only hope that Fox release aftermarket metric shocks.
Posted : 16/05/2017 9:09 am
They will release them, you can currently buy them from places around europe.
Posted : 16/05/2017 10:02 am
Currently having the same dilemma as the OP.
Got a couple of European trips coming up so want to replace the Monarch on my Scout with something with a piggyback. Probably an air shock.
I went down the coil route last year (Banshee Prime), since sold the bike, never used the coil apart from abroad. The weight difference was too significant, and the lack of climb switch was also an issue.
So my options given the size requirement appear to be:
DB Air CS £575
Fox Van with a tune £unknown as not clear what's included. Likely £400-£450 I guess
Pushed Float X £599
Anyone have any thoughts/experiences? Favouring DB Air at the moment.
Posted : 16/05/2017 10:17 am
 poah
CCDB coil IL with valt spring is about 650g, a CCDB air or X2 is 500ish grams.
Van RC with the MX tune is about £500 but no climb switch.
Posted : 16/05/2017 10:25 am
But no piggyback on the IL, so doesn't really help with the fact this purchase is being driven partly by the desire to have a piggyback shock for heat dissipation.
Argh
Posted : 16/05/2017 10:36 am
 poah
IL has 40% more oil and no air spring to heat up.
Posted : 16/05/2017 11:02 am
DB Air CS £575
Pushed Float X £599
None of them.
DHX2 as you are little limited on size for that bike.
Or a DBCoilIL.
Posted : 16/05/2017 11:08 am
Interesting. Cheers gents.
Does the DHX2 come in 190x50? Couldn't see it. Either way I suspect it's out of range price wise.
And good points on the DBCoil IL. 40% more oil compared to what? A non CC inline shock?
If the DB Coil IL will perform better than a DB Air CS for these trips then maybe that's the way to go.
Posted : 16/05/2017 11:20 am
 poah
40% more than standard inline shocks e.g monarch rt3, float dps etc.
Posted : 16/05/2017 1:37 pm
Had an interesting chat with a tech at TF.
The in-house experience of two of their employees of the Scout plus DB IL Coil is that it's good. It changes the character of the bike. The shorter stroke length means that on bigger hits it does blow through the travel easily, and you can't totally tune it out with HSC.
I can see that - you're running it at 30% sag, you've only a two inch stroke, so you're going to need a pretty dramatic ramp up, which might be outside the range of the shocks adjustment.
The two guys have gone back to air shocks since (Fox DPS).
I don't want a Fox DPS - same issues in bigger mountains as a Monarch I presume. Ideally, I don't want a change of shock to massively change the character of the bike - I like it as it is, just want to make it a bit more suitable for a bigger mountain application.
So am now wondering whether air is indeed a better choice for me. Either Float X or DB Air are the ones available in 190x50.
Posted : 16/05/2017 2:46 pm
 poah
DVO topaz
Posted : 16/05/2017 4:15 pm
Who is servicing the Topaz at the moment? Anyone?
Posted : 16/05/2017 4:43 pm
 poah
TF do, they will probably tune the shock for you too
Posted : 16/05/2017 5:18 pm
Nice, cheers. Got lbs on the case currently so will see what they come up with. Topaz looks good though if the support is there.
Posted : 16/05/2017 11:42 pm
I've got a Scout with a Van RC MX tune and a Pushed Float X. They feel different, I run much less sag on the coil to compensate for the more linear stroke but it is more supple and I think there is more grip. Not having a climb switch is a problem when you think too hard about it but it's easy to forget about once you go down again. I think on balance that I prefer the coil most of the time.
Posted : 17/05/2017 12:05 am
Hello All,
Did anyone have any luck fitting a X2/DHX2 to a fuel ex 9?
I am looking to change the shock out ideally with an X2 but the dimensions are 210*52.5 and there aren't any stock with that measurement.
Lots of people say about putting some 'ghetto' plastic shim inside to work, but it doesn't sound legit.
Thanks!
Posted : 23/06/2018 12:09 pm
I’m in the same boat.
im on my third shock on the Fuel.
Sram think my frame may be out of alignment as the shaft is worn on one side.
theyre sending an RC3 out under warranty, but the frame has gone to Trek to be checked.
the Fuel is the best bike I’ve ever ridden, a coil could make it even better.....could it?
Posted : 23/06/2018 8:38 pm
A 210x55 shock fits and doesn't have any clearance issues, obviously it bumps up the travel a little bit.
I run a 210x55 Push ElevenSix on my Fuel.
I would say the coil improves it significantly.
Posted : 23/06/2018 8:59 pm
