Fox Service - Dampe...
[Closed] Fox Service - Damper unit
Servicing my forks, not doing the damper service though just a seal and oil change. Do I leave the oil in the damper unit or squeeze it out?
Posted : 29/06/2011 1:43 pm
What forks?
Posted : 29/06/2011 1:48 pm
Fox 32 Float R 2007
Posted : 29/06/2011 1:50 pm
from the fox float service
Note: Before proceeding from this point, be sure that you have drained all oil from the damper cartridge.
To remove oil from the damper cartridge, very gently insert a small hex key (1.5 mm) into one of the ports. This action will open the spring-loaded check shim. While holding the check shim open, gently push and pull (very slowly) on the top cap several times. This subsequent action will pump the old oil out of the cartridge. Perform this operation over the oil drain pan.
Posted : 29/06/2011 2:15 pm
