Fox Performace vs R...
Fox Performace vs Revelation
 FOG
My X Fusion Trace fork is on its way out so I need a new fork. I have been offered either a Revelation Motion Control Debonair 35mm or a Fox Performance Grip 34mm at virtually the same price but I have no experience of either. Is there any realistic difference or is it just eeny meeny?
Posted : 03/12/2025 6:16 pm
Option B.
Posted : 03/12/2025 6:23 pm
Grip damper is infinitely, infinitely better than the Motion Control - that fell out of favour years ago and is really quite outdated.ย
Rockshox forks with some of the later Charger dampers make this a much more difficult choice, but with the two specs you've listed I'd take the Fox fork all day every day.ย
The Grip/Sweep style damper is massively better (and in some cases preferable to the Grip 2 as well).ย
Posted : 03/12/2025 6:25 pm
kelvin reacted
A STW consensus.
The Fox Grip is well regarded, the Motion Control really is quite pants.
Posted : 03/12/2025 6:36 pm
Fox all day
Posted : 03/12/2025 6:54 pm
Agree with the above, Fox all day long. Motion Control was poor 5 years ago.
Posted : 03/12/2025 8:14 pm
Definitely Fox, the performance is better than even the lower end charger dampers and miles better than motion control
Posted : 03/12/2025 8:16 pm
Charger damper I'd go RS, but fox performance level against old moco, fox every day of the week. Infact any fox level over moco, Rhythm is still a bloody good fork.
Posted : 03/12/2025 8:24 pm
 P20
Rev Mc On the hardtail and Fox 34 on the full suss. Fox 34 every time. The revs will either be upgraded to charger damper or swapped out for a pike. The fox damper as mentioned above is much better
Posted : 03/12/2025 10:45 pm
I was gonna defend the MoCo damper in my Yaris, but then I remembered Id swapped it out for an Novyparts Splug
Posted : 04/12/2025 10:21 am
 StuE
Might be worth consideringย
https://share.google/TtTs7l5Rt52mL2Sp j" target="_blank" rel="noopener">DVO Diamond D1 Boost 29-Inch Fork https://share.google/TtTs7l5Rt52mL2Spj
Posted : 04/12/2025 11:24 am
