fox fork and shock ...
[Closed] fox fork and shock service DIY how to help please!!
[#4006040]
Hi all, my fox triad shock and fox float forks could do with a basic service and I would like to have a go myself.
Ive stripped a pair of revelations before so I have no issues trying to do it.
Is there a how to guide anywhere on how to do them ??
failing that has anyone done there own that could give me some hints and tips please!!
cheers
steve
Posted : 24/05/2012 6:00 pm
Have a look on the mojo website, theres also pretty comprehensive guides on the fox website too.
All pretty straightforward stuff.
Posted : 24/05/2012 6:05 pm
http://www.mbr.co.uk/advice/how-to-service-your-fox-float-air-can/
That's for the air can service. And this is for the wiper seals on the forks.
http://www.mbr.co.uk/advice/fox-forks-workshop-dust-wiper-oil-change/
Posted : 24/05/2012 6:38 pm
As above - take your time. You'll need a 10mm deep socket and a flattened 26mm one IIRC. Good luck!
Posted : 24/05/2012 7:21 pm
 LoCo
Thanks for the replies.
just a quick question about my rear shock, i dont think it has a bolt that goes through the bottom hole as there is some sort of extender on the bottom of it(2010 stumpjumper frame)
has anyone done the a service on the same model?? if so does the extender just unbolt or somthing?
Posted : 24/05/2012 7:37 pm
