If one were to reduce the travel on a set of Floats from 140mm to 120mm, would the A-C reduce by 20mm?
Posted : 12/06/2011 8:20 pm
Yes. Just reduced mine from 160 down to 100 and a2c drops.
Posted : 12/06/2011 8:43 pm
By 60mm?
No, by the same distance as the spacer(s) you have fitted. Sounds like you have rebuilt it incorrectly. Take it apart again and check?
Posted : 12/06/2011 8:53 pm
Posted : 12/06/2011 10:25 pm
As far as I'm aware if you add a 20mm spacer then the axle to crown will be 20mm less. So if you add 60mm worth of spacers then the axle to crown will be 60mm less.
Posted : 12/06/2011 10:29 pm
Yeah, the travel reduces by the amount of spacers you add - so I added 60mm so drops 60mm - if you do the same with 20mm then 20mm should be the result.
Posted : 13/06/2011 9:27 am
