Ello. So I have just aqquired a stumpy full suss frame off my brother in law. Swapping things off my hardtail with glee. Can anyone advise on setting up the float r rear shock as I have never done this. Also I am thinking the spaces on my bb need to be different to the 2 on the drive side I have currently on my hardtail? Any advice appreciated.:0)
Surely someone must have a stumpy with an ht2 bottom bracket? ๐
How to set up a rear shock [url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/010/eng/index.html ]HERE[/url] Getting hold of a shock pump and a sag meter will help. Your LBS should be able to help you out.
BB set up [url= http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/tech_support/tech_tips.download.-Par50lparsys-0003-downloadFile.html/Hollowtech%20II%20Crank%20Installation.pdf ]HERE[/url] Again proper BB tool will make the job very easy.
HTH
sag meter = a ruler!!
Width of BB will determine how many spacers you need
Ah yes cheers guys.
