fox float forks not...
[Closed] fox float forks not using full travel
3 Users
Can anybody help me I have a set of fox float 130 mm drcv forks and they wont use all the travel.they used to until recently ive tried running less pressure in them but it hasnt made a difference. Even if I let all the air out the fork they wont fully compress can anybody help?
Posted : 25/09/2013 12:51 pm
They don't compress fully .. Maybe around 15mm spare ??
Posted : 25/09/2013 12:52 pm
Id say about 25 mm spare.
Posted : 25/09/2013 12:56 pm
It could be the piston o-ring has gone in the air side chamber, this allows the bath oil in the bottom of the air-sping lower leg to migrate to the upper chamber thus locking out the travel. Give mojo a call and explain to them what is wrong and order the correct o ring + replacement foam seal.
edit : but without physically seeing the fork i'm only hazarding a guess.
Posted : 25/09/2013 12:59 pm
Ok cool Will give that a try.
Posted : 25/09/2013 5:36 pm
