about to splash out on some Fox F29 forks like [url= http://www.pricepoint.com/detail/19479-315_FOXQR0_KIT-3-parts-429-29er-parts/Fox-32-F29-F120-RLC-Fit-QR15-2010.htm ]these[/url]
does anyone know the difference between the 100mm and 120mm versions (and i don't just mean 20mm haha)
is there just a spacer inside which allows you to convert from one to the other? or is the travel actually fixed at that length?
i'd like to get the 120mm, but it'd be nice to know that i can change down to 100mm if i ever need to
not sure if this helps but i converted my 80mm to 100mm by removing the spacer.
quick phone call to a mate who,s got the 100mm f29rl and he,s under the impression he can make his forks 120mm by removeing the spacer.
still dont no if you can make the 120mm ones 100mm though so im still not much help.
cheers for taking the time to phone your mate! very good of you
it sounds like i'll be able to do it one way or another
is it an easy task to add/remove the spacer?
yes dead easy couple of bolts, bit of oil allen key and follow the online instructions i just used google.
also if your forks come with a spacer in a jiffy bag type thing. then thats your answer.(as in yes you can reduce their travel).
strange that it's an extra 10 quid for more travel, when the products are essentially the same! i guess they assume people have more money than sense ๐
cheers for your help
Converted my 80mm into 100mm. Good move for the bike's geometry.
80mm and 100mm can be converted back and forth.
120 can be converted to 100 or 80.
100's can't be converted to 120. Or at least the 100's i have can't as there's no spacers to take out.
