Hi, i was thinking of buying a Cannondale trigger bike from pauls cycles, does anyone have any experience with the fox dyad rt2 shock. Im a bit nervous to purchase because of this, just wondered if theres anyone here that has one and could tell me if its reliable and possible to service yourself. Thanks Rob
As reliable as a normal fox shock ime.Important to get serviced regularly though ,which is a pain as it costs £142 and no home bodging...not even a can service.
And run really high pressure (up to 450psi!!!).....which means you need a special shock pump.
Nevermind just got this of fox webite
WARNING: THE DYAD RT2 SHOCK IS NOT USER SERVICEABLE, OTHER THAN REMOTE CONTROL CABLE REPLACEMENT. NEVER ATTEMPT TO REMOVE THE SPOOL CHAMBER END CAPS FOR ANY REASON! ATTEMPTING TO PERFORM ANY INTERNAL SERVICE PROCEDURE ON THIS SHOCK CAN POTENTIALLY RESULT IN SERIOUS INJURY OR DEATH.
i was hoping the shock would come with the bike, i better check that thanks
I have one on a jekyll and love it. Mine went for a service and was beyond repair so for my £142 Mojo sent me a brand new one in return
It does.i was hoping the shock would come with the bike, i better check that thanks
thanks for replies, does anyone have any thoughts on the bike, its this one, http://paulscycles.co.uk/m1b0s183p5686/CANNONDALE-TRIGGER-4-27-5-2015
Or any other suggestions for about a £1000, needs to be small size though.
