Fox Bushing - Cheap...
[Closed] Fox Bushing - Cheaper Alternatives?
Need a complete new bushing set for my new shock and at £20 for a few washers and stuff, seems a little OTT. Are there any cheaper alternatives than what Fox/Mojo offer? BETD etc?
Shock is a Float RL and the frame is a SC Blur 4X.
Dave
Posted : 01/09/2010 9:09 am
the bushing itself is a DU08
Posted : 01/09/2010 9:15 am
tf tuned
Posted : 01/09/2010 9:19 am
take an old one (or the DU08 code) to your local bearing supplier, they'll have them in cheap as chips.
Posted : 01/09/2010 9:24 am
The simple alloy C-style DU bushings you'll get from a bearing shop do not last as long as the O-style plastic jobbies you get from BETD.
Posted : 01/09/2010 9:29 am
BETD myself 🙂
Posted : 01/09/2010 9:30 am
messiah - Member
The price difference means that's irrelevent to me.
Posted : 01/09/2010 9:38 am
Sorry, should have been more clear. As well as the bushing, I also need the spacers that sit between the shock and the frame - would TF/BETD be able to supply those too for less than the £20 that Mojo charge?
Posted : 01/09/2010 9:45 am
I'd rather spend the £20 and get the proper kit. Its your suspension and frame here. Save the few pounds elsewhere.
Posted : 01/09/2010 10:01 am
You'll have to measure the reducer by removing the frame unless someone has teh same frame as you and has already measured it.
TBH You are looking at £18 + postage from BETD for the bushing and reducer. So if fox can supply you with one free postage for £20 then it'll be cheaper and presumably they will fit it for you so no need to buy a bushing tool? Unless you have to do it often then try Mojo for the easier option. If you want to do it yourself then go with BETD 🙂
Posted : 01/09/2010 10:35 am
