Fox 34 adding some ...
[Closed] Fox 34 adding some oil to the air chamber - presumably easy diy job?
So I want to add a little oil to the air chamber of my Float 34's for a bit more progressive action but I'm not sure exactly where it goes in and can't seem to find anything on tinternet. Once you have let the air out is it the big (26mm?) cylinder that comes out and then drop about 10ml of oil in? Or does just the valve come out, or is it that alloy ring thing that you take out to get in there?
I presume it's some of that Fox Float Fluid that I use?
Any guidance before I get the tools out and balls it up would be appreciated!
Cheers.
Posted : 26/04/2013 9:27 am
