have been toying with the idea of getting somes new forks for my hemlock, been looking into the 32 float, 150 fit rlc. are these good for general trail riding or is there somthing better for the £. as these are kashima coated i could also send my rp23 to mojo to get this also?
I've got some 150mm and 140mm Float's with Kashima and I think they're excellent in my opinion. Small bump sensitivity is very good and they're sturdy for their travel too. They look the dogs danglies as well 🙂
There's a guy selling some brand new ones on Pinkbike and they're going quite cheap too.
You won't find much better short of a BOS.
I use them on my Rocket. Brilliant forks.
Thought they were pretty good on Cy's Rocket 🙂
Unless someone has stock they'll be the new 2013 CTD numbers though. Not sure availability but should know soon enough as whatever my new bike is the forks will either floats or Bos (160mm Devilles).
Also looked at Revs which can be picked up for between £4-500 from the usual suspects...
any one know whop has the best prices for these?
does fox still have issues with seals? would i be better off with some rockshox, dont wanna spend £750 on some forks that will be worn out in a few years due to poor seals
FIT forks? You must like giving Mojo money an awful lot!
mojo didnt want my money :D, said i need to use one of the dealers
has anyone tried the new 2013 forks with CTD-ADJ. guessing these are different to fit dampers? are they still small bump sensitive? will they work ok with a rp23 what does not have CTD-ADJ, just normal pro pedal
tf tuned has these, anyone used these before?
